2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Drone after putting down pipe on 535
      08-17-2018, 07:37 AM   #1
sshah261
Drives: 2011 535i xDrive
Hi all,
What are my options to get rid of drone after install my down pipes? My current setup is VRSF down pipe with a Msport axle back exhaust. I'm getting a lot of drone at lower rpm. Don't hear it much in the front when driving but ppl sitting in the back do complain about it.
Thanks!
      08-17-2018, 02:38 PM   #2
E90705
E90705's Avatar
Drives: E90/F25 M-sport
Did you recently install one or the other?
      08-17-2018, 04:35 PM   #3
sshah261
No it's been over a year
      08-17-2018, 04:47 PM   #4
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
tell the people in the back to take an Uber if the noise is that bad lol! if not maybe look into some J pipes
      08-17-2018, 07:36 PM   #5
E90705
E90705's Avatar
Decat DP?
J pipe mod or add resonators before the mufflers.
Err worst case scenario throw back on the stock DP and/or stock exhaust if you can't live with the drone.
https://f10.5post.com/forums/showthread.php?t=1239526
Another option is to install some dynamat/ butyl mat or some sound insulation in the trunk area for your passengers.
      08-20-2018, 08:29 AM   #6
txoid
Drives: f10
Adding sound insulation will not help with the MPE. I even added sound insulation to the heat shields and didn't see a difference.
      08-20-2018, 08:31 AM   #7
sshah261
Driving under sport mode (putting the shifter to the left position) I hear less drone but in normal driving there's a decent amount more. I'm going to look into doing J-pipes, hoping that helps
      08-20-2018, 09:51 AM   #8
203banshee
203banshee's Avatar
181
Drives: F10 535, F25 35i X3, EVO 8
add a resonator . A cheap solution that may or may not work.
      08-22-2018, 12:07 PM   #9
ssgm1x
ssgm1x's Avatar
Drives: 2020 M340i & 2018 M3
Originally Posted by sshah261 View Post
Hi all,
Thanks!
you have to remove the stock resonator and install Vibrant resonators to get rid of the drone...many people have fixed Drone this way....
2020 BMW M340ix Dravit Grey
2018 BMW M3 Alpine White
