2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications David Shoup Tune
      04-08-2020, 11:43 AM   #177
Bmwdoubles_
Bmwdoubles_'s Avatar
Drives: BMW F10 535
  [0.00]
Originally Posted by ziekxq View Post
Originally Posted by Bmwdoubles_ View Post
Good stuff. Can't wait to find and fix my leak. I'm keeping my AZ-MCRacer inlet. I fitted it with part of the stock grommet so there's no unmetered air happening at that point. I think my leak is at the valve cover which i don't have prior to the DS tune. Which means his tune found my weak points when setting the target to 22psi.
I am just wondering if he is getting me to 20psi now and adjust tune for timing then how much I can get out of Helix. I think lpfp stage 2 is helping as that is one of the things David Shoup asked me about before I bought his tune. I think I am also going to get the breather oil cap to help with crankcase pressure.
Not sure what the combo of a upgraded lpfp and helix can actually do. Just keep in mind there's going to be engine limits as the N55 is not reinforced. If you can clear the 500-550whp I think that would be the limits of a semi dependable street build.
BPM Tuned, Advanced Fuel Dynamics, Paddoq Valved Exhaust, Paddoq Magnetic Paddles, EDC dampers, Dinan Springs, H&R Sway. DCT all day long.
https://www.youtube.com/channel/UCFu...fWjCtOz49FDMlg
      04-08-2020, 12:11 PM   #178
ziekxq
Drives: 2011 535i xDrive
If I can do 550whp then I am happy. As long as I am not WOT every stop light and every day all the time then I don't think 550whp would be an issue. I do not plan on taking it further then that. I know people saying you don't need lpfp upgrade if you go Helix, but I think with straight E85 it is must to have a stage 2 lpfp to keep up with demand. I could be wrong and you might prove me wrong once your car is done tuning.
      04-08-2020, 01:30 PM   #179
Bmwdoubles_
Drives: BMW F10 535
  [0.00]
500whp is a lot of power, key being whp. Be careful and responsible with that power as it can quickly get out of control on you in a dangerous way. My recommendation would be to take a few autocross courses or get some track time to know your limits. I know when my car is at its limits, however once this tune is done I'm going to have relearn my car.
      04-08-2020, 02:02 PM   #180
ziekxq
I am AWD so it is different for me compare to your RWD plus I run sticky summer tires.
      04-08-2020, 02:10 PM   #181
BimmerHausPerformance
BimmerHausPerformance's Avatar
513
Drives: 2011 535i 6MT
2011 BMW 535i  [0.00]
I don't think the demand is the issue with the LPFP I think it's the compatibility with full e85, meaning the ethanol will ruin the pump.
2011 F10 S55 6MT
Website Insta @bimmerhausperformance YouTube
      04-08-2020, 04:11 PM   #182
ziekxq
Not sure why David Shoup asked me, "are you at least running stage 2 lpfp?" Even though he knew I am only using 93 octane and had 0 clue regarding my Helix OD plans. I think there is a psi difference too between the OEM pump vs stage 2 pump. But honestly I would love to go back to OEM lpfp if lpfp stage 2 is useless.
      04-08-2020, 04:30 PM   #183
513
Ask him! He will know... Lol, don't listen to me!
      04-08-2020, 04:34 PM   #184
ziekxq
Or I am wrong and I told him in excitement about the Helix OD and e85 lol and now forgot about it.
      04-08-2020, 05:06 PM   #185
$howtime456
$howtime456's Avatar
301
Drives: BMW 640i
i run the 525 Hellcat pump. On e30 e40 never had a problem with y 450 on e50. Soon as i went pass that the e85 put a strain on the EKPM3 and left me stuck a couple of times. My advice. If your plannning onrunning e50+ get yourself a 525 hellcat pump where the fuel pressure rises with the boost and an ekpm3. If your lower then you should be fine.
N55 GENERAL
David Shoup Tuned
Fully Built By Miami Engines/Project Motorworks
Precision 6266 On Steroids
      04-08-2020, 07:44 PM   #186
ziekxq
Do you mean bpm4? My car already got ekpm3 Module and I always get the power too high for the pressure Code. That is I rather go back to stock pump lol, than spending 700 dollars on a module. We will see how it goes and maybe I will go bpm4 route if needed.
Side note, car is completely different on a 20psi tune.
      04-08-2020, 07:45 PM   #187
ziekxq
Did you ask David about the lpfp at all or has he said anything?
      04-08-2020, 09:50 PM   #188
Bmwdoubles_
Drives: BMW F10 535
  [0.00]
No i have not asked.
Pros and cons on our fueling choices.
Mine takes care of top end fueling but makes a metal clanking sound occasionally.
Yours holds good pressure up top too but could potentially melt your top hat or ekps or both or have a hose pop off.
People using meth could blow up their car either by no ecu control under detonation or worse a line breaks loose.
      04-08-2020, 10:24 PM   #189
ziekxq
I am going to get Helix OD soon hopefully. I am running lpfp stage 2 for over a year now. I will remove the back seat next time I am getting oil change done to see how everything looks.
      05-07-2020, 08:24 PM   #190
513
Any updates on this Bmw doubles? ziekxq
2011 F10 S55 6MT
      05-07-2020, 08:27 PM   #191
Bmwdoubles_
Drives: BMW F10 535
  [0.00]
So far making 430whp. We'll get 500whp but i have a boost leak and wgdc are at 95%. Thought I fixed it so now i need to smoke test it. The car rips even with the leaks.
      05-07-2020, 08:29 PM   #192
513
Is David waiting for you to get that sorted out or does he even need to? I would imagine he's feeding in the boost but you just can't hold it...?
Awesome stuff.
2011 F10 S55 6MT
      05-07-2020, 09:48 PM   #193
ziekxq
430whp... What psi you at and what timing are you running?
      05-08-2020, 06:25 PM   #194
Bmwdoubles_
Drives: BMW F10 535
  [0.00]
Peak 22 because I don't have my 3.5 tmap is.
https://datazap.me/u/bmwdoubles
430whp to the top! When the leaks are fixed I'll should be smashing on a lot cars. There an N55 out there on IG smashing on lambos! I'll share soon.
      05-08-2020, 07:52 PM   #195
ziekxq
I think I am going to sell this car and move on.... We have been trying but timing corrections don't want to go away... Tried 93oct + 3 gallons of e85 but no difference. I am giving up hope. I already tried changing plugs and coils twice.
      05-09-2020, 02:12 AM   #196
MOBF10
MOBF10's Avatar
171
Drives: 2018 M3 Comp
Anyone know if David tunes ewg n55's. I know his FB says early model n55's but I'm leaning more toward a custom tune to get off the OTS maps and would love to go to someone highly recommended.
      05-09-2020, 02:37 AM   #197
Bmwdoubles_
Drives: BMW F10 535
  [0.00]
I feel ya bro the N55 is not a tuner friendly platform. I've been scoping F10 M5's also e90 M3's. 2 different worlds but V8's are the next list. How much power did you finally pull out of yours? Roughly? The B58 motors on the 3 and 440's are producing large power!
      05-09-2020, 02:40 AM   #198
Bmwdoubles_
Drives: BMW F10 535
  [0.00]
Yes he does EWG and honestly you're going to get better results than us PWG guys. Your down pipe is 4" and ours is 3.5 plus EWG you get full control of the WG. If I had the 4" DP and EWG with the upgraded hpfp for that platform i would be way past 500whp. I'm hitting 430whp to the top with problems
MOBF10171.00
