01-28-2021, 04:03 PM | #1 |
Rep 35
2012 535i engine noise
Hi,
I'm not sure if this is normal or not but my car makes this noise. ~84k miles, all service has been done when it was supposed to. Video link Any opinions? |
01-29-2021, 02:08 PM | #4 |
Rep 179
Drives: BMW 535i F10
My engine makes similar noise when its cold but it goes away after few minutes when the engine warms up. 130k miles. Should I be worried? I thought it was normal
01-29-2021, 04:23 PM | #6 | |
Rep 15,858
If it is the ticking, most of the N55 engines have an injector sound track like that, at varying levels. Mine's quieter than your sound track. Fuel can make a difference, using a fuel additive in a tank of fuel, like BMW's (Techron) additive may help quieten them down for a while. |
OnlyGerman363.50 |
01-30-2021, 02:58 PM | #7 |
Rep 35
I only use fuel from Shell 91. Never used additives or anything else. Once I get the gasket cover fixed hopefully it will be better..
What is worrying me more is the white smoke that was coming into the cabin.I treated this car like a baby, but I guess these are all normal maintenance things for an 84k mile car. |
01-30-2021, 03:49 PM | #8 |
Rep 265
I googled and got this:
The head gasket seals the internal combustion process and keeps coolant and oil from mixing together. A perforation to your gasket or a blown head gasket usually occurs as a result of an overheated engine. When coolant flows into the combustion chamber from a blown head gasket it burns/evaporates into white smoke. OR is this white smoke from exhaust that is seeping in? |
div1ne21.50 |
01-30-2021, 04:12 PM | #9 |
cals
17
Rep 34
the ticking noise can be a symptom of low oil (or very thin oil); have you checked the Oil level?
smoke into the cabin can be a oil/coolant leak that drops in the exhaust manifold, that creates the smoke and gets sucked into the cabin but you should be able to confirm that checking if there is indeed something leaking |
01-30-2021, 04:23 PM | #10 |
Rep 35
First of all, thank you all for taking the time to reply.
@Trian it does sound like that's what's happening. The smoke was coming from the left upper side of the hood. @cals Although I have seen a small oil stain on the driveway after the car sat more than 2 weeks, I have constantly checked the oil and it's been at max level ever since I got the oil change, ~1500 miles ago. I am taking the car to a service on Monday so I'll be back with some updates |
OnlyGerman363.50 |
01-31-2021, 03:29 PM | #11 |
Rep 79
At this mileage, with the engine temperature that the car runs. It's usually valve cover (gasket), pretty common issue.
Head gasket is a completely different thing, normally you shouldn't have those problems if you keep the fluids up to date. |
div1ne21.50 |
01-31-2021, 04:38 PM | #12 |
Rep 2,591
Smoke from the top left is almost always the valve cover. Oil drips onto the hot catalytic converter/exhaust mani which is right there and gives you that smoke. You'll often times smell it in the cabin too because the blower is right around there too.
2015 BMW 535xi
OnlyGerman363.50 div1ne21.50 |
02-01-2021, 06:46 AM | #13 |
Rep 15,858
Been there, exactly as you say.
02-01-2021, 06:49 AM | #14 | |
Rep 15,858
The sound we are hearing is fuel injector noise. It is a bit louder than most will be, but 'DI' injectors are not typically silent. (N20 injection sounds very diesel like). |
02-01-2021, 10:02 PM | #15 |
Rep 35
The car is in the shop until tomorrow, they said besides the valve gasket leak there is another coolant leak from the radiator. Those will be replaced and we'll go from there.
The guy said there was an warning sign showing low coolant but I never saw one and I check the status of the car fairly often. Also, another question: Whenever I stop at a light, ASS goes in and turns the car off. When I take my foot of the break to go, the car switches to P/N by itself. I don't mind the ASS, but sometimes when I'm not aware it switched to P/N I will rev it and I'm the last to leave the traffic light. Anyone else had that happen to their F10? |
02-02-2021, 09:28 AM | #17 | |
Rep 2,591
2015 BMW 535xi
02-02-2021, 10:04 AM | #18 | |
Rep 179
P.S. I was getting no warning sign that my battery was dying, I found it on my own when car didnt start on the first try... So don't rely on warning signal, check it with bimmerlink or with tester. |
OnlyGerman363.50 |
02-02-2021, 02:35 PM | #20 |
Rep 35
Good news! I got the car back, and these were the items that were replaced:
Coolant leak: Radiator hose- upper Cooling hose- lower Radiator Coolant Valve cover gasket: Valve cover gasket set Breather hose Total:$1600 @OnlyGerman They did suggest that, I declined and that will be the next item on the list to replace. As far as the ASS goes, they said the battery is at 70-80% so that can be the reason. Since it's not at 100%, it will prioritize where to send the power and will cut off extra features like ass to make sure everything else gets enough. 2nd item added to replacement list. It's not a terrible inconvenience, I usually disable the ass feature anyway. I looked it up and as far as I understand it could be solved with some coding or battery replacement. I love this F10 design and the car drives really well Thank you everyone for the advice! Last edited by div1ne; 02-02-2021 at 06:10 PM.. |
02-03-2021, 05:23 AM | #21 | |
Rep 15,858
It's not necessarily a sign of a failing battery. Even if you charge it to 100%, after some use it can drop back to ~80%. The alternator will not be charging the battery to maintain 100%, (it's only supporting demand above about 80%), as battery capacity is left for over-run energy harvesting. There are a multitude of factors why ASS doesn't function. Charging the battery will eliminate the battery being the cause, if ASS works after an additional charge. |
