01-15-2021, 11:35 PM | #45 | |
Rep 4,633
This is incorrect. You are missing how things move and expand when it is all connected, esp on the turbo side. And the flex section is not mesh on the oem pipe? To keep it short, I am gonna take the oem route and engineering here.
Current: E63S AMG 4matic RENNtech || M5 Evolve..Eventuri || F10 LCI 535i MHD
01-16-2021, 12:30 PM | #46 | |
Rep 2,591
If it worked like how you think it does, it would have 2 flex sections. One on the turbo side, and one past the transmission bracing. Which, it obviously does not have.
2015 BMW 535xi
01-16-2021, 08:28 PM | #47 | ||
Rep 423
Checkout my YouTube channel, Like and Subscribe. https://www.youtube.com/user/Gjohnson7771 MHD Flash, RVG Catless DP, RVG CP, RVG Boost Pipe, Walbro 455 LPFP, Style 433 Wheels, BC Coilovers, Ebay Strut bar, M-Sport Front Conversion, RVG FMIC, 6WB Cluster. |
01-18-2021, 07:47 PM | #48 |
Rep 78
Drives: 2014 535i xDrive
Allright, just got the part came in today. Here is some picture of the flex, the craftsmanship of the flex looks a lot better in real than on the original picture, everything looks fine. Another thing is I ask another business (VRSF) if their downpipe does come with a flex for our 3.5" turbo and to my surprise they reply it does not, so it sounds like catless may not need it because it does not get as hot, question is do you still need it ? Anyhow, the RGV I just got looks great to me.
Next step is to install, I will keep you posted after. On ECS tuning, they show the VRSF DP with a very similar flex from the 4.0" turbo, have a look. https://www.ecstuning.com/b-vrsf-par...xoC2DUQAvD_BwE Last edited by T-Bone18; 01-19-2021 at 08:40 AM.. |
Jamesmick131.00 |
01-20-2021, 10:13 AM | #49 |
Rep 538
Does look much better in person! Let us know how install goes.
Are you doing it yourself?
'16 Carbon Black Metallic F10 535i M-Sport - TOTALED 11/21/21 '13 Black Sapphire Metallic F30 335i M-Sport - unknown charge pipe, MSport Exhaust, 20" 405M wheels, $61k MSRP, CF M4 Mirror caps & Spoiler, NGK plugs, Dinan Coils, BMS intake |
01-20-2021, 03:56 PM | #50 |
Rep 78
01-20-2021, 11:00 PM | #51 |
Rep 78
RVG Performance just release their new website, check it out.
https://www.rvgperformance.com/ |
ramman434712.00 |
01-25-2021, 09:09 PM | #52 | |
Rep 78
I did re-install the DP with the same gasket and with the same V-band. The V-band was not easy to put back on but when you have the downpipe align, you have to squeeze it pretty hard, had to use vise grip at one point. The 2 issues I ran and is one of the bolt of the car bracket that support the downpipe broke I did not bother replacing it because there is another one higher that holding it. The other one is I had a seize O2 sensor in the original downpipe, had to go see my mechanical so he can heat it up and loose it. Unfortunately I don't have a torch. I just finished tonight so only had time to flash it BM3 Stage 2 with the No cat options so I don't have a check engine light. In the flashing, I also remove the "Heating cat option" but I kept the Startup Roar. Just by giving her few rev, you can already feel the turbo spooling freely. Can't wait to go for a ride tomorrow. Best tip, if you do this under your car like me on jack stand, get yourself some safety glass. Here is the broken bolt that I did not replace, but you can see that the DP bracket align nicely. Also this clamp here is welded to the mid pipe. Last edited by T-Bone18; 01-25-2021 at 10:09 PM.. |
01-26-2021, 10:46 AM | #53 |
Rep 538
That fitment looks great! Thanks for the feedback!
I'm planning to piece together my exhaust, then download Bootmod3. Just taking my sweet time lol. I'm waiting on these guys to figure out their hiccups on the 4.0" for the '14-16s
03-05-2022, 03:37 PM | #55 |
Rep 2
I just installed the RGV in my 2011 F10 today and the bottom tab did not come close to fitting. I could not use it. It is only secured by the top tab. I'm surprised with everyone saying how the RGV fit was perfect and mine wasn't close.
03-06-2022, 09:30 PM | #56 |
Rep 1,442
Drives: 2011 535i 6MT
I haven't had an aftermarket down pipes tabs ever fit on a car. Expensive or cheap. N54's, n55 f10's, f30 n55's etc
03-23-2022, 09:56 PM | #57 |
Rep 78
Yeah the back part did not fit in perfectly but deep and tight enough that I don't think it had any leak. I had it install for over a year now and I'm happy. Looking to upgrade with RVG boostpipe now.
03-24-2022, 09:24 AM | #58 |
Rep 423
That is confusing. My RVG downpipe fits great! Have you reached back out to RVG for feedback? Maybe he changed manufactures and had an issue.
04-27-2022, 09:17 AM | #59 |
Rep 234
I just placed an order for my 2014 535, build date of 01/2014 but still have the PWG.. So weird.
I'll let you guys know how the fitment goes of the 3.5" pipe from RGV. |
04-27-2022, 01:59 PM | #60 | |
Rep 5,015
https://mad-us.com/mad-bmw-n55-f1x-2...pipe-4-0-only/
slobo7x44.00 |
04-30-2022, 07:13 AM | #61 | ||
Rep 234
The fitment is 99% on, only issue I had was getting the new Downpipe to slide into the stock midpipe.. it feels like the opening is the same OD, so the pipes needs a bit of heat to make them cooperate. Other then that, fantastic product and fantastic shipping speed and quality! Hope that helps anyone who's looking to order one. Last edited by slobo7x; 05-02-2022 at 01:38 PM.. |
