09-21-2020, 03:12 PM | #1 |
Rep 36
Drives: 2015 535i msport
Thermostat replacement
a visit to the dealer has been a nightmare.
first it was the gasket for the oil pan now they are saying I also need the following items. Sparkplug replacement--431 MicroFilter -- 180 Oil Pan Gasket- 2191.00 Thermostat Replacement- 798.00 sos emergency call malfunction- 725.00 Is changing the Thermostat pretty something that I can do at home? Seems expensive. I would hate for my car to over heat. ughh. Thermostat housing leaking coolant. |
09-21-2020, 05:03 PM | #2 |
Rep 648
spark plugs and microfilter are easy to do. The back 2 are annoying because of the rubber matt (which I got rid of) and the crossover cables (brackets held in place on either side by 2 torx screws) but not impossible.
The thermostat isn't hard per say, but you need to have patience to get to it as some of it you have to feel your way around (kind of crammed in there if you have big hands), but certainly not too difficult. An afternoon on a Saturday and a beer should be more than enough.
11' M-sport- 371 WHP-478 WTQ on stock PWG// DYNO COMING FOR Shuenk N55+ on 91oct/ BHP Intake/ IC/ CP/ DP/ Valved Mufflers/ David Shoup Tuning/ B58 Coils+N20 NGKs/ Walbro 450/ Helix OD/ xHP3/ G12 Brembos |
09-21-2020, 06:29 PM | #3 |
Rep 36
that would over 1k in savings...
Ill start looking up some vids and see about doing it myself. Just not sure if I need to change the water pump while im replacing the thermostat? |
09-21-2020, 07:06 PM | #4 |
Rep 452
Water pump is a bit harder. Especially if you have active sway bar. But best to do them together. Make sure you also get 1 gal coolant and 1 gal distilled water
09-21-2020, 11:11 PM | #5 |
Rep 68
Drives: 2011 535ix M-sport
If you are having the dealership change the spark plugs for you, then the thermostat might be a little difficult for you. The spark plugs are easier to do, still a little process, but easier.
Depending on your mileage, the thermostat is usually done in conjunction with the water pump. The reason is to do the coolant system once and the thermostat has to be removed to get the water pump removed. If you haven't done something like this before, plan double the time to do it and perhaps have a buddy join you who has more experience. Search water pump changes so you can get an idea of the work and the parts. 95blkmax The rubber isolator over the rear spark plugs are not just there for noise suppression. The rear doesn't have the rubber isolator that the engine cover does. The rubber isolator doubles to block exhaust/turbo heat to prevent heat soak of the fuel rail. I would return the rubber isolator if I were you.
'11 535ix M-Sport - FMIC, CP, BM3 engine & trans, CQuartz Finest Ceramic, Poly tension bushings, Dynamic, Active Roll, Flappy paddles, HUD, Premium(s), Cold, Convenience, 5-cameras, 4-zones, Driver's Assist, Auto high, Hex trim
'92 850i, '08 XC90 3.2 Past: '93 525i w/ S38B36 M5 engine/trans swap, '99 540i/6sp Sport, etc. |
09-21-2020, 11:26 PM | #6 | |
Rep 659
10-02-2020, 01:50 AM | #7 | ||
Rep 639
