2010 2011 BMW 5 Series Forum F10 New N63 engine installed, update. |
02-01-2019, 10:25 AM | #1 |
Rep 99
My N63 seized up on July 31st after a rod bearing overheated and failed. It was a long journey to get a new engine with the whole recall and lawsuit, but I picked up my car yesterday and the engine purrs.
I decated my cats, basically have a 3 inch hole thru them so I was worried if the dealer/warranty would deny my claim, but he only asked me if I want to replace them, I declined and they proceeded with the swap. I think I need a new battery now, probably because its been sitting in the dealer lot 6 months dead and my carbon fiber spoiler is toast from the sun, alignment needs to be done because the steering wheel sits a little sideways when going straight, other than that I'm glad I have my car back. The "long block" motor was a little under $4k, labor was $6.2k plus a few other parts, total was $11,200, my portion out of pocket was 500ish. This was done with my aftermarket warranty. I'm probably one of the very first people with the new N63 engine out there Suggestions if I should do an oil change after a 1000 miles or so? Break-in suggestions? |
02-01-2019, 10:34 AM | #2 |
Rep 17
Wow I've been waiting for 8 months now for a replacement engine. Congratulations though good to finally see someone get one. Also how long did it take the dealership to install it?
02-01-2019, 11:15 AM | #3 | |
Rep 659
02-01-2019, 11:17 AM | #4 | |
Rep 99
Service manager told me I was the #2 customer on the list and they have 9 more. There's gotta be a lot of people waiting for motors out there.. |
02-01-2019, 11:24 AM | #5 |
Rep 99
Nope. I have an old post on here somewhere with the drawing, and I believe people said it wouldn't work. But, I did it and no check engine light. At first, the check engine light came on, but it was showing that the cats were basically too clean lol. After a day or two the light turned off and been off ever since. If I had to get emission testing done, I'd pass with no issue, even tho the guys there would be choking with all that untreated exhaust.
I drilled a 2.5inch hole thru the cats and put a stainless pipe thru it and cemented it in place with high heat glue/epoxy. So most of the gases go thru the stainless pipe and never have any contact with the second 02 sensor. So there's very little gas reaching the sensor and by the time it does, its very clean/lean. |
02-01-2019, 04:17 PM | #6 |
Rep 215
Wait...they didn't do a wheel alignment after pulling out the engine from your car? Plus you paid your share? I would have definitely questioned them as to why the car doesn't drive true. Also please tell me you did confirm the new warranty on your new engine?
Kyngofpop676.00 |
02-01-2019, 04:54 PM | #7 | |
Rep 99
And yes, the service manager said 2 years/unlimited miles warranty from the factory. |
02-01-2019, 09:18 PM | #8 |
Rep 5,691
Engine is pulled through the top, suspension is not touched so an alignment wouldn’t be part of the repair.
02-01-2019, 10:15 PM | #9 |
Rep 215
I was under the impression that the cradle was dropped and the body lifted?
Watch "Bmw 550 F10 engine removal N63 - Removendo motor bmw 550 F10" on YouTube |
TinCanSailor629.50 |
02-01-2019, 11:19 PM | #11 |
Rep 99
The SA told me it gets dropped from the bottom, they had to remove the steering column at the very beginning so they could troubleshoot the engine failure, had to remove the lower and upper oil pans, so whatever they did, they definitely messed up my alignment and now the steering is angled to the left and the car is all over the road.
02-04-2019, 11:53 PM | #12 |
Rep 333
Lucky, mine was 2 years ago, replaced with used motor thru aftermarket warranty at tune of $18k I think? BMW wanted around that for the block then.
02-08-2019, 02:38 PM | #15 |
Rep 59
Hi all. I am sorry to hijack your thread, but if someone could direct me to the right place, that would be great.
I just bought a 2011 550i M Sport with 79,xxx miles on it. I did not buy it CPO, and I do not have a warranty. I thought I did my research on this car, but after purchasing it, I see I did not. I see the class action against BMW, and I see the recall as well. I cannot return the car -- trust me, I tried begging and pleading to the dealer who essentially told me to piss off. I put $3k down and owe $13k. The trade-in value for the car is somewhere around $9k. I have already put $600 in tires, $150 in diagnostic at BMW, and authorized $2500 in repairs repairing coolant issues and diverter valves. If I traded it in, I would be essentially taking a bath of nearly $10k. I just cannot do that. Is there a thread to direct me to information about the recall -- if my car is even covered under it? I looked up the current open recalls on my car, and the only one open right now is an electric turbo coolant pump. Any help is appreciated. |
02-10-2019, 03:53 PM | #16 | |
Rep 150
Otherwise, likely worst case is your engine goes and likely best case is you get endlessly bent-over every few months for $2k-5k in repairs. |
Kyngofpop676.00 |
02-12-2019, 08:41 AM | #17 | |
Rep 17
02-12-2019, 10:20 AM | #18 | |
Rep 659
02-12-2019, 10:51 AM | #19 | |
Rep 1,299
I understand they make massive power but they also come with massive issues. My brothers dealership got the new m550s with 6k miles having issues. Good luck, I would say sell it private and get ride of the problem or you will end up spending more money in repairs than the car's worth. |
02-12-2019, 04:19 PM | #20 |
Rep 659
this is exactly why im done with BMW V8s after I get rid of my 550 and going back "Murican" lol
M550s look nice, but them problems, Im not bout that life. Thought about going the F10 M5 route, but all Im reading are bent rods issues These vehicles nowdays are built to service. smh Last edited by 535_BiTurbo; 02-12-2019 at 04:28 PM.. |
Kyngofpop676.00 |
02-13-2019, 04:49 PM | #21 |
Rep 659
What did you end up doing with your car?
02-13-2019, 04:57 PM | #22 | |
Rep 1,299
