08-09-2020, 07:27 PM | #1 |
Rep 659
Transmission oil leak
F10 550... It seem like im leaking transmission oil after a long drive and the car is turned off. Short drives there is no leaking but long drives with stop and traffic there is a leak. The oil is clear. Anyone else have this issue?
08-09-2020, 10:33 PM | #2 |
Rep 658
Sounds like you need to replace the trans pan (gasket and filter are all integrated to the pan). At that point you'd also be doing a drain and fill (not full flush). It will take a little under 4 bottles to fill back up to level per fill instructions.
11' M-sport- 371WHP - 478WTQ on stock PWG E50 TunedbyShoup // 386WHP - 429WTQ on Shuenk N55+ with ultra-conservative 91 Octane tune // Starting full-range flexfuel tuning in Spring '24 |
09-18-2020, 10:08 AM | #5 |
Rep 659
problem solved. replaced the trans pan/filter, trans cooler and radiator
