2010 2011 BMW 5 Series Forum F10 Help with spacers on 550 f10 |
09-03-2020, 11:29 AM | #1 |
Rep 35
I want to keep my original rims 19 inch m sports and maybe same tires stock on BMW 550i m sport staggered but I want to make them stick out just enough to be flush with the car everyone keeps telling me to go with 10mm spacers but I want you guys opinion .
09-04-2020, 09:52 AM | #3 |
Rep 2,637
Do you plan on lowering the car at all? Lowering gives more negative camber, and the front camber is non-adjustable by default so if you do lower you might need even more up front.
2015 BMW 535xi
Jbarrer213.50 |
09-04-2020, 09:59 AM | #4 |
Rep 35
Yes bro , I actually just ordered the dinan springs with bump stops, should lower about an 1inch from what I've heard after it settles
09-04-2020, 10:37 AM | #5 |
Rep 1,907
I've been toying with the idea of spacers too since I installed the KWs. I didn't see a huge need before but now it looks a little odd.
I used an offset calculator and plugged in the numbers from the staggered rear option and it seems to say that a one inch (25mm) spacer on the rear would bring it equivalent to a stock staggered stance. That seems a little much but *shrug*, 15mm doesn't eyeball as enough. Everyone might find this useful: Tire sizes and wheel offsets from https://www.wheel-size.com/size/bmw/...drive-usdm-300 Offset calculator https://tiresize.com/wheel-offset-calculator/ I'm not lowered a ton, 1.25" maybe? I set the KWs up so they were 2/3 to 3/4 toward the "top" of the recommended range because I specifically didn't want to go too low. |
09-04-2020, 11:38 AM | #6 | |
Rep 35
09-04-2020, 12:56 PM | #7 | |
Rep 624
09-04-2020, 01:08 PM | #8 | |
Rep 1,907
Square is 8.5JX19 ET33, staggered rear is 9Jx19 ET44. Spitballing the math agrees too: they won't want to be any closer to the suspension so half inch wider wheel, 11mm further out (checks out). The tire is 30mm wider section (245 to 275) so 245 is a "skinny" fit on an 8.5 and 275 is a wider fit on a 9.0 (30mm wider tire on a 12mm wider wheel).... Doesn't sound outlandishly crazy. The car is filthy right now but walking up to it I saw that the sun angle highlighted how things look and leave something to be desired. Actually the harsh shadow on the rear doesn't really show well just what the vertical gap looks like, but does show the need for spacers. Anyways this is a square 351M 8.5Jx19 245/40/19 set up after being lowered about 1.25". It gives about one finger of gap, my car is level with the front. I attached a couple more trying to show gap - but my rear pic still sucks. |
09-04-2020, 01:22 PM | #9 | |
Rep 1,907
The fancy calculator seems to say that to put the wheel + tire in the same apparent location as staggered needs 25mm, which I agree seems like a lot. |
09-04-2020, 02:59 PM | #10 |
Rep 2,637
In terms of using a calculator, using the M5 343M fitment is pretty spot on as a reference point. On my car, the wheels are pretty much flush with the fender in the back and only about 3-4MM away from being flush (due to camber) in the front..
The fronts are 20x9 ET34, rear is 20x10 ET34
2015 BMW 535xi
09-04-2020, 04:14 PM | #11 | |
Rep 1,907
Would like pics I was comparing my F10 to a friend's F10 M5 and the fenders are flared noticeably more. That would likely mean that a set of M5-spec 20s would protrude more than they would appear to on an actual M5. |
09-05-2020, 03:04 PM | #12 | ||
Rep 29,212
09-06-2020, 09:53 PM | #13 | |
Rep 2,637
Honestly, the poke is so little you'd only ever notice it if you're at the front/rear of the car and looking dead straight down the side.
2015 BMW 535xi
