02-25-2018, 12:28 AM | #1 |
Rep 182
Spacer vibration
Hello, today I installed a 15mm spacer on my front wheels. I noticed a vibration going 35mph+. I have an M5 fender thus needing a wider spacer. Also, i'm on xdrive with coilover if that changes anything. Does anyone have a similar problem? I got these off eBay they look and feels very nice and yes they're hubcentric.
02-25-2018, 12:35 AM | #2 | |
Rep 4,209
http://www.burgertuning.com/BMW_wheel_spacers.html |
02-25-2018, 01:08 AM | #3 | |
Rep 717
02-25-2018, 01:16 PM | #4 |
Rep 182
https://www.ebay.com/itm/15mm-Hubcen...72.m2749.l2649.
Does it really make a different since they're just spacer?? I don't really know this is my first time getting them. |
02-25-2018, 01:16 PM | #5 | |
Rep 182
02-25-2018, 07:02 PM | #6 |
Rep 4,209
Take them off and clean them. Make sure there is no rust on the rotor which could be causing a gap. Even though you might not be able to see it, you're feeling it when you are going 35 mph.
02-25-2018, 09:28 PM | #7 | |
Rep 717
02-25-2018, 11:18 PM | #8 |
Rep 14,521
I have a feeling they are not mounted correctly
02-26-2018, 01:11 AM | #9 |
Rep 182
Exactly what I'm doing. I will report back. I didn't clean the hub and the wheels before mounting the spacers that's a big no no.
02-27-2018, 05:03 PM | #11 |
Rep 14,521
good to hear!
Ickdeep5719.00 |
02-28-2018, 03:38 PM | #12 |
Rep 14,521
i knew it either wasn't mounted correctly meaning the normal sand and brush and use brake cleaner to wash off any residue from brushing that way the spacers mount perfectly flat on the hub
