2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding BMW F10 Coding DIY (and other Fxx models)
      07-15-2025, 05:37 AM   #749
shawnsheridan
shawnsheridan's Avatar
Drives: 2018 Alpina B6 650ix GC
Originally Posted by stvai View Post
Hello, I'm looking for E-Sys and a version of ISTA with spanish SQLiteDB...
(I got the v4.39.20 working with my F10 but it didn't come with the spanish SQLiteDB file (ES_4.39.20.7z).
Thanks a lot.
PM sent. I cannot help with Spanish SQLiteDB.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      07-26-2025, 05:04 PM   #750
onelinez
Drives: BMW 535i X-Drive
Originally Posted by Jason View Post
See the comprehensive coding DIY and discussions @ http://www.f30post.com/forums/showthread.php?t=696777
I just purchased a 2013 535i and I want to start coding. I wanted to view the comprehensive guide...but, it doesn't seem to exist. I'd like to learn as much about coding as I can.
      09-02-2025, 03:00 AM   #751
MontyPara
Drives: BMW F10
hello shawnsheridan can you please send me the e-sys software?
I have a 2011 F10
Thank you
      09-02-2025, 09:24 AM   #752
shawnsheridan
I have a 2011 F10
Thank you
PM sent.
      10-28-2025, 06:39 PM   #753
mypos5mikes
Drives: BMW F10, E39
Has anyone with a US F10 (Mine is 2014 F10 LCI) coded their US language to UK, to then be able to select German (or Deutsch)?
I'm hoping to code for both system language and iDrive speaking language, for German.
Appreciate any help, thank you!
      12-08-2025, 02:41 AM   #754
GPT_M340i
GPT_M340i's Avatar
Drives: BMW M340i & BMW M550i
F10 Rear Fog light
Hi,
Has anyone coded rear fogs to turn on with the front fogs using the front fog light switch?
If it's possible, does anyone have the coding reference for BimmerCode to activate the rear fogs with the front fogs light switch. Any input is appreciated as I've been trying to locate it but can't seem to find it.
Thank you !
      12-13-2025, 05:21 PM   #755
AlfaDon
Drives: 2005 BMW E46
I just picked up a new to me 535d, and could use the coding list. I got suckered into buying Carly, but will move to Bimercode after the year is up.
shawnsheridan can you help me with this?
Thanks
      12-15-2025, 06:14 PM   #756
GPT_M340i
GPT_M340i's Avatar
Thanks
Here's a bunch of cheat sheets I used for the F10
Give it a go & have fun coding !
File Type: pdf F10 Cheatsheet - F10 Cheatsheet clean.pdf (76.0 KB, 35 views)
      12-16-2025, 12:33 PM   #757
AlfaDon
Thanks!!
I appreciate it!
      12-28-2025, 06:59 PM   #758
Darkas
Drives: Bmw F10lci
any one have info and programs to do f10 anti-glare function to work?
i have US spec car that was decoded for this
5AP - Decode anti-glare high beam assistant
8S4 - Decoder variable light distribution
i have Led adaptive headlights S552, S5AC, and KAFAS camera i think so
Now headlights turns when turning steering when and high beams only auto On and OFF not doing any light distribution
      12-29-2025, 03:29 PM   #759
zrile
zrile's Avatar
Croatia
186
Drives: BMW F10 520d
Hi,
Thank you !
Why not just buy switch with both foglights buttons? Or try dissasemble it, that lower plastic cover just have some stopper, i think that button is under it. I have seen guys on yt posting it is possible to unblock it and use that as a button for rear fogs. And, i can't believe the car has no rear fogs.... usually cars are not equipped with front fog lights.
      12-31-2025, 12:51 AM   #760
Mykel
Drives: BMW 550i
Smile
hello shawnsheridan can you please send me the e-sys software too?
I have a 2011 F10
Thank you
      12-31-2025, 01:31 AM   #761
shawnsheridan
I have a 2011 F10
Thank you
Your PM function is disabled. Send one when enabled.
      12-31-2025, 03:47 AM   #762
GPT_M340i
GPT_M340i's Avatar
Didn't wanna buy the whole switch assembly just to add 1 button. My switch isn't like the one with the blank button that has the stoppers. My previous F30 had it, I shaved the stoppers & coded rear fogs for free lol. For the F10 switch, I ended up taking it apart & found out its possible to add a rear FL button. Ended up ordering a new face plate & a button to make it work.
It would be nice to have rear FL button included with the car. Since they aren't mandatory in North America, Bmw didnt add the button for us even though the car has the hardware.
zrile186.00
      12-31-2025, 06:24 AM   #763
Mykel
Drives: BMW 550i
shawnsheridan I need to wait 7 days to enable it first.
      12-31-2025, 04:48 PM   #764
shawnsheridan
Wait no more. PM sent.
      12-31-2025, 08:04 PM   #765
Mykel
Drives: BMW 550i
Wow! Thanks shawnsheridan
      01-06-2026, 08:47 PM   #766
zrile
zrile's Avatar
Croatia
186
I cannot understand for rear foglights that they are not mandatory equipment in usa....im from central europe, rears are mandatory on all cars, at least only left for lhd countries or only right for rhd countries. Front foglights are additional equipment. 🙉🤯🤣
      01-07-2026, 12:18 PM   #767
Mykel
Drives: BMW 550i
HELP!
I got no sound at all or anything. No doors nothing 😭 😭 😭 😭
My error codes
B7F821 description Speaker output leads, front left: open circuit
B7F825 description Speaker output leads, front right: open circuit
B7F829 description Speaker output leads, rear left: open circuit
B7F82D description Speaker output leads, rear right: open circuit
B7F8B4 description head-unit to SDARS aerial foot: open circuit
B7F87F description CIC: Coding data implausible
E1C448 description MOST: actual configuration incomplete / MOST nodes central function block database incomplete
INFO 93000F description MOST nodes: signed out at least one function block
E1C448 description MOST: actual configuration incomplete / MOST nodes function block database incomplete
I don't know where to start
      01-14-2026, 08:23 AM   #768
kipparing
Drives: 525xDA
Firmware F11
Hi, i'm in France, looking for firmware update for my 525xDA 2012, since last year, i can't get "Services à distance" they told me i need firmware update.
I didn't find any on BMW site.
Thank's for your answer.
Regards
Antoine
      01-14-2026, 11:43 AM   #769
shawnsheridan
Regards
Antoine
      01-16-2026, 12:39 PM   #770
GRHighlander
Drives: F11 520d
Originally Posted by gzmdesign View Post
Hi fellows, after a few days of not being able to do anything on my new F11 due to work, I have now found some unexpected free time and was able to get a few things coded in. Keep in mind all of these have been done using BimmerCode as I don't have E-sys or a compatible cable...... and I'm lazy too... that too...
CAR: 2016 F11 520D M-Sport / HU-NBT
EBT (Office menu)
First thing, I was having a lot of trouble getting this to work, for instance, I could get the Office menu, but wouldn't see texts or emails, or I could get texts, but no cover art over BT, or I would lose voice commands and the ability to summon Siri from the steering wheel button... eventually I started looking into what each item on the cheat sheets did and found what worked best for me:
Attachment 2042803
This particular coding got me the following:
- Office menu
- Covert Art over USB and BT
- Full SMS from my iPhone (no email though, still working that one out)
- Full use of voice commands and Siri button
- All other functions as before
If anyone has anything to add that would aid in getting emails to work I would be grateful.
Remember you will have to forget your phone from the Bluetooth menu and forget your car from your phone, once all the coding is done, you should pair them up again.
Compass and x-Drive menu
I wanted the Compass displayed on my 6WA dash, and then I found that you could enable xDrive Status even if your car is not xDrive, to show the compass and pitch and roll (I don't think torque is working)
I have also coded the m550d logo, on the dash but that one I'm sure you all know by now how to do.
These are the items that worked for me:
Attachment 2042786
See below for pictures of the result:
Attachment 2042788
Attachment 2042787
Video-in-motion and extended Codec pack
I've installed an SSD on the central console with a few movies (all legally owned ) and just enable these settings:
Attachment 2042793
I can probably upload a video if anyone wants to see how that looks while working but here is a few pics:
Attachment 2042795
Hope this helps if someone is having a bit of a headache like I was specially with the Office stuff.
Next steps for me will probably be trying to code SPORT+, but all my reading says it cannot be done just yet on BimmerCode for my F11 at least. Again, if anyone has any input, more than glad to listen
Hello,
How do you display XDrive Status?
I have already coded it.
