2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Adjustable End Links Rear Sway
      04-12-2024, 09:30 PM   #1
John H.
John H.'s Avatar
Drives: 2022 G15
Installed SuperPro adjustable end links for rear sway.
HI_F1067.50
      04-16-2024, 10:54 AM   #2
DementedF10
DementedF10's Avatar
Drives: 2012 BMW 535ix
I put gas in my car
s_ribs134.50
      04-17-2024, 07:41 AM   #3
John H.
John H.'s Avatar
Drives: 2022 G15
Originally Posted by DementedF10 View Post
I put gas in my car
Good.
      04-23-2024, 01:12 AM   #4
Unspec
Unspec's Avatar
1485
Drives: 2015 BMW 535xi
Part number?
2015 BMW 535xi
ISTA VM Setup/Tutorial
      05-11-2024, 10:13 AM   #5
John H.
John H.'s Avatar
Drives: 2022 G15
Originally Posted by unspec View Post
part number?
trc1025a
trc1225a
      05-11-2024, 04:15 PM   #6
Unspec
Unspec's Avatar
1485
Originally Posted by John H. View Post
trc1025a
trc1225a
Why are there two part numbers?
2015 BMW 535xi
      12-14-2025, 12:05 AM   #7
Carbon535i
Carbon535i's Avatar
Drives: 2015 BMW 535i xDrive M sport
Sorry this is really late, but I am doing my endlinks currently. The reason for two part numbers is because the top of the endlink is a M10 stud and the bottom is a M12 stud. The TRC 1025A is for the M10 set and the TRC 1225A is for the M12 set. You have to swap the halves to make a complete set.
      12-19-2025, 10:19 AM   #8
Bagelfast
Bagelfast's Avatar
146
Reason for adding adjustable end links?
Was the bar hitting anything? was it under tension?
I thought the general forum thoughts was the rear sway almost never needs adjustable endlinks even when lowered, no tension or clearance issues.
