2010 2011 BMW 5 Series Forum F10 10.5 width Wheels with 285 michelin tires. |
04-25-2012, 01:35 PM | #1 |
Rep 1,583
Does anyone have any pics of 10.5 width wheels and 285 michelin tires or any other tire? I want to know if a 285 tire will look flush with a 10.5 wide wheel.
2013 M6 Coupe SG, VSE 003's 21, Akropovic Evo Carbon, KW V3, AMS DP's, Vorsteiner Full Aero, Gruppe M Intake, Bel Stir Plus & V1 with HP Laser Interceptors, P3Cars Gauges, JL 2X12W6Subs, 35%tints.
My Thread: http://www.6post.com/forums/showthread.php?t=794659 |
04-25-2012, 01:56 PM | #3 |
Rep 1,583
So if I go 295 rears on an xdrive dropped on ACS with a 40 offset what size profile should I get in the back with what size tires in front on a 9 inch wide wheel?
04-25-2012, 02:59 PM | #4 |
Rep 8,808
I wasn't able to find a right tires size up front to go with 295 rears. This is the issue with having a xdrive car.
for RWD cars the overall diameter doesn't matter as much as i've seen people run 255 up front with 285 rears etc.... but that might freak out the xdrive system since the overall diameter of both sizes are different. If you plan on running 285 michelin, i would stick with a 10" wide wheel if you don't want stretch.
04-25-2012, 06:19 PM | #5 |
Rep 1,583
Thanks guys..Problem solved staying with 10inch wheel.
04-25-2012, 09:26 PM | #6 |
Rep 96
Drives: 2011 alpine 535i
Go to 1010 tires they have a tire calculator it really helps tells you all you need 285/35/20 and 255/40/20 is almost perfect that's what aim going with
04-25-2012, 11:18 PM | #8 |
Rep 1,583
Yeah, I wouldn't do that setup. Best is 245/35/20 front and 285/30/20 rear. Offsets are also a factor in rubbing.
04-29-2012, 08:51 PM | #9 |
Rep 32
You guys are wrong I have a 2011 BMW gt535 xi I am running 22 by 9 in the front with 245/30/22 tires and 22 by 10.5 rear with 295/25/22 no issues at all with the x drive wheels fit flush no rubbing in rear or front
04-30-2012, 11:35 PM | #11 |
Rep 1,583
post some pics!
05-03-2012, 03:31 PM | #12 |
Rep 32
