2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Caliper paint brush or spray?
      11-18-2015, 04:29 PM   #1
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
For those that have painted their calipers which method did you use brush or spray paint? Any preference over one from the other? I figure with the spray paint u can get some evenly coverage if applied right. With the brush I would think you don't have to mask everything off (wheel well, suspension, fender) just the rotor assembly.
I decided instead of gloss black I'm thinking of satin black unless you guys think gloss would be a better way to go aesthetically? I'm also planning on painting the hub and the shield black too!
      12-04-2015, 09:00 AM   #2
Wully32
Drives: 2009 ///M3 2012 X5
Spray
I sprayed my front and rear calipers. They look great.
      12-04-2015, 09:33 AM   #3
Simple5
Drives: F90 M5 and E84 X1 Xdrive35i
If you paint use a foam brush. I've never sprayed before.
      12-04-2015, 10:16 AM   #4
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
I painted using a brush takes longer but no need to mask everything off and you can get right into the smaller area and behind and on the underside. You will get better coverage imo
2014 M5
1990 E30 318i Touring
1999 E38 728i -sold
M235i - sold
Activehybrid 5 - sold
      12-04-2015, 10:46 AM   #5
lsturbointeg
Good input! I'm assuming the clear would have to be applied by brush too?
      12-04-2015, 10:50 AM   #6
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
I just sprayed the clear. Quick spray over
2014 M5
1999 E38 728i -sold
M235i - sold
      12-05-2015, 11:55 PM   #7
bin01123
Drives: 2011 750i
2011 BMW 750i  [0.00]
2011 BMW 328I  [0.00]
I've done both methods. The brush provided better coverage and lasted much better
      12-06-2015, 06:24 AM   #8
lsturbointeg
Does the paint come out evenly? No brush strokes visible?
      12-06-2015, 08:21 PM   #9
bin01123
Drives: 2011 750i
It does come out evenly however I believe the preparation and cleaning of the caliper is probably just as important. Making sure the caliper is clean of dirt, grease, road grime, etc. ensures that the paint will stick and last. Otherwise the paint will probably chip over time.
      12-06-2015, 09:16 PM   #10
macastel
Drives: BMW 550i
Can you guys post some pics of the finished project?
      12-30-2015, 10:55 AM   #11
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
Pics
2014 M5
1999 E38 728i -sold
M235i - sold
      12-30-2015, 11:29 AM   #12
lsturbointeg
Pics
Hasser, did you just do that right now or was this done awhile back? looks really really GOOD!
      12-30-2015, 11:41 AM   #13
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
was done in October I think it was.
using brush.
2014 M5
1999 E38 728i -sold
M235i - sold
      12-30-2015, 03:27 PM   #14
Zer0Cool92
Drives: blue metallic
Yeah brush is much better. You can lather on some nice thick coats with it
      12-30-2015, 07:40 PM   #15
lsturbointeg
When springtime ever comes around I'll get to it but at the same time I'll be swapping out the suspension with coilovers.
      12-31-2015, 09:43 AM   #16
bin01123
Drives: 2011 750i
Pics
Where did you get that paint color and the logo? That's way better then spending a boat load of money on M sport calipers
      12-31-2015, 09:47 AM   #17
lsturbointeg
The logos can be purchased from eBay
      12-31-2015, 10:07 AM   #18
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
paint was from amazon.
foliatec is the company- pretty well known in the automotive industry.
logo was just off ebay - there is loads on there.
2014 M5
1999 E38 728i -sold
M235i - sold
      12-31-2015, 10:19 AM   #19
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
http://f10.5post.com/forums/showthread.php?t=1182269
2014 M5
1999 E38 728i -sold
M235i - sold
      01-02-2016, 11:52 AM   #20
top6491
MSGT USMC (Ret)
Drives: 2012 AW F10 535i M-Sport
2012 BMW 535i  [0.00]
Calipher painting
I spray painted mine and they still look great (even though they are white) after 20 months. Takes a little more time yes in setup, but the actual painting then goes quick. Considering you do multiple coats (that then only take a few seconds each to spray) the prep work time averages out. The brake lines are long enough to be able to set the brakes on a block of two 2x6s I used to paint them on. My pics are too big to post but could email if you wanted to see.
You can see pics of the car on the VMR website at http://www.velocitymotoring.com/vmr-...llery_type=vmr
I rep their V710 wheels.
      01-06-2016, 09:53 AM   #21
LACSTER
Drives: Hybrid
I used VHT spray.
Close ups.
      01-06-2016, 09:55 AM   #22
LACSTER
Drives: Hybrid
Here's a really simple DIY I wrote when I did my wife's hybrid.
http://www.clublexus.com/forums/ct-2...-calipers.html
