2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Anyone running 20x9.0 et 35 with 255/35/20 in front?
      04-11-2017, 10:10 PM   #1
gearheadred
Drives: 2014 550i
Hi, All. Just installed my new wheels - 20x9 et 35 with 245/35/20 in front and 20x10.5 et 42 with 285/30/20 in rear. Wheels fit fine, pretty flush, but I don't like the stretch on the tires. Any successfully run the same size in front with a 255/35/20 tire, without rubbing? Rears have plenty of room to go to a 295. BTW, this is on a 550ix, M-sport, stock ride height. Thanks for the help!
      04-12-2017, 01:31 AM   #2
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
9x20" ET35, 255/35-20 is a safe setup.
There is actually room for maybe 10mm more aggressive offset with that tire size.
      04-12-2017, 11:06 AM   #3
ItBloo
Fish Gill
ItBloo's Avatar
73
Drives: 2018 Accord Sport | 1995 540i
1995 BMW 540i  [0.00]
2012 BMW 535i  [0.00]
Yes I am. No issues whatsoever.
Bloo The Bimmer - 2012 BMW 535i (15%/5% Tint | Dual Slat Grillle | H&R Sports)
Bessie The Bimmer - 1995 BMW 540i
      04-17-2019, 05:55 AM   #4
Lukaas54
France
Drives: BMW F10 530d
Hi dude,
No issue or rubbing with 9x20 ET35 in front ?
Thanks
Lukas
      06-06-2019, 10:25 PM   #5
gearheadred
Drives: 2014 550i
Sorry for the late reply.
No issues with that setup on the 550ix, or the 550i that I now have. The front with 255 was tight on the suspension side, but never rubbed.
      06-06-2019, 10:52 PM   #6
ey2001
ey2001's Avatar
310
Drives: F10 535i 6spd
I have 20x9 ET 25 running 255/35/20 PS4 and I'm good so you should be fine
      06-15-2019, 11:36 AM   #7
Luky
Luky's Avatar
Drives: 2016 550i M Sport
Anybody running this in the rear (Square set up)? What does it look like? Any fit issues?
      06-27-2019, 09:07 PM   #8
Mitchell431
Mitchell431's Avatar
Drives: 2016 M5
2016 BMW M5  [8.75]
I'm trying to run a 20x9 255/35R20 and hoping for a 305-315/30R20 I'm not sure what offsets I need car will be bagged I don't want to spend the money on LM's and have them not fit can anyone help? If I have to I'll do a 295 but I've seen 305-315 pilot sports and r888
      06-27-2019, 11:28 PM   #9
ey2001
ey2001's Avatar
310
I have 20x9 ET 25 255/35/20 Michelin 4s and 20x10 ET 40 295/30/20 Michelin 4s
      06-27-2019, 11:52 PM   #10
Mitchell431
Drives: 2016 M5
2016 BMW M5  [8.75]
How's fitment flush? Pretty aggressive? I'm wanting the aggressive look. Pic if you have one thanks!!!
      06-28-2019, 10:43 AM   #11
ey2001
ey2001's Avatar
310
It's pretty flush... I guess the order changed when I uploaded... first pic is rear second is front
      06-28-2019, 01:48 PM   #12
remmib
remmib's Avatar
Norway
1569
Drives: 2013 F10 520d M-Sport
I've tried my fronts, 255/35/20 ET26, in the rear without rubbing, so the ET35 will definitely not rub.
      06-28-2019, 02:15 PM   #13
Mitchell431
Drives: 2016 M5
2016 BMW M5  [8.75]
Is there enough room in the to run a little higher offset in the rear to fit a 305?
      06-28-2019, 04:09 PM   #14
ey2001
ey2001's Avatar
310
I think 305 will rub on my setup if I have people in the back
      06-29-2019, 02:24 AM   #15
Mitchell431
Drives: 2016 M5
2016 BMW M5  [8.75]
I wonder if a 42-44 in the rear would eliminate that or if it would hit suspension 🤔
      06-29-2019, 02:41 AM   #16
Mitchell431
Drives: 2016 M5
2016 BMW M5  [8.75]
We have diamond black BBS LM-R in stock in 20x9.5 ET 23 and 20x11 ET40
Somewhere has these local would still do the 255 and most likely will do the 295 even though I want the 305.
      06-29-2019, 03:51 PM   #17
remmib
remmib's Avatar
Norway
1569
My rears are 20x11 ET46 with 295/30/20 Michelin PS4S tires.
They don't rub, but it's really close, and I don't think ET40 would clear with those tires and my lowered ride.
The Michelin's are pretty big in size, so other tires in the same size might run smaller and fit.
It also depends how low it is. If it's not lowered, you'll need much more load in the car to get the wheel tucked into the wheel well where it can rub.
      07-06-2019, 03:58 PM   #18
addy27
Drives: F10 550i
I'm running 255 35 20 fronts with a 20x8.5 and 295 30 20 on rears on 20x9.5 (yeah the rear does look a tiny bit like a donut) but these sizes make the outer diameters of the tires between front and rear almost identical.
      07-25-2019, 01:25 PM   #19
artjr
Drives: 2012 BMW 550i
i'm running a 9.5x20 ET28 with 255/35 no rubbing at all. ever. stock height currently. going to 245/35/20 tire when i install the Vogtland sport lowering springs in about 2 weeks.
      07-25-2019, 09:42 PM   #20
Luky
Luky's Avatar
Thanks. Could you send me pics showing how flush they are? Are you running a square setup?
      07-26-2019, 12:14 PM   #21
artjr
not square, no. the rear is 10.5x20 ET 32 with a 285/30/20.
      07-26-2019, 12:16 PM   #22
artjr
i can give ya what i got now and take a few more if you need them?
