2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum What is this leak?
      09-01-2018, 09:09 PM   #1
TZ
Drives: 2011 535i xDrive, 2014 435i CO
What is this leak?
Today I removed the underneath engine cover and found a sign of leak (Picture 1) . Trace it down and found the stain on the lower part of the coolant hose from the bottom (Picture 2). There is also light stain can be seen from the top on the coolant hose (Picture 3). The leak is hard to tell oil or coolant fluid. I carefully checked around and could not find the source. it is not the famous oil cooling housing (Picture 4)
What it would be?
2011 535i xDrive Black/Black, Michelin PS AS 4
2014 435i RWD Convertible
Service Manual: www.newtis.info
Part: http://www.realoem.com
      09-02-2018, 10:42 AM   #2
BurrNinja
What it would be?
Possible ofhg? Looks a bit grimy on the last picture near filter area on left side? thats my assumption. Have you taken engine cover off and checked around valve cover gasket also?
Instgram @burninja
      09-02-2018, 03:56 PM   #3
NinetyEight740
NinetyEight740's Avatar
Drives: 2 - 2013 535i msport
2010 E91  [0.00]
Is it engine oil? Could be the seal on your intercooler piping allowing small amount of oil and air to escape.
      09-03-2018, 06:45 AM   #4
tcabill
tcabill's Avatar
Drives: e63 650i, F10 535i, E93 335i
Looks like oil filter housing to me.
      09-03-2018, 09:49 PM   #5
TZ
The oil filter housing is clean (picture 4).
I cleaned them up and will take a good look next time.
      09-09-2018, 09:33 AM   #6
paul223
paul223's Avatar
Drives: F10
Intercooler connection on turbo side.
