2010 2011 BMW 5 Series Forum F10 cannot open boot from remote f10 |
01-27-2019, 11:23 AM | #1 |
Rep 52
Hi
For some reason, after software upgrade I cannot open boot from remote, button inside is working just remote is dead. In which module should I look to enable it ? Thanks |
02-01-2019, 06:54 AM | #4 |
Rep 1,873
Double check the valet switch in the console (it should be correct if the footwell button opens it, but worth checking). Does the trunk/boot button on BOTH keys fail to open the lid?
The problem could be the key. I'm not sure if there is a coding option for opening the boot. The common coding option is to enable CLOSING the boot from remote. |
02-03-2019, 11:34 AM | #6 |
Rep 34
No clue what the problem is. But maybe you could try to rule out any unexpected coding changes.
For instance, you could try checking the Boot lid opening delay to verify that it isn't set to a very high value in seconds. The boot lid opening delay might be found in Bimmercode under Front Electronic Module/Car Access System. Not saying that's the problem. Just that it might be worth checking. That's all. |
