2010 2011 BMW 5 Series Forum F10 How much oil does your n55 consume? |
02-13-2019, 08:40 AM | #1 |
Rep 79
My '11 535i goes through a liter of oil every 2k miles... Doesn't look normal to me.
Recently i changed the oil filter gaskets, head and valve cover gaskets and the oil pan gasket as all of them were slightly leaking. Oil consumption is a bit better, but still a lot. Could all this be from blow by? Car is running a catless dp and mhd stage 2. |
02-13-2019, 09:00 AM | #2 |
Rep 1,873
So far, my 2011 535xi does not consume a measurable quantity of oil between changes (no segments are lost on the oil level indicator). I have changed oil anywhere between 0.5-1x the factory interval. Usually more like half the interval, around 10,000km (not miles).
02-13-2019, 09:35 AM | #3 |
Rep 697
Drives: 2013 535xi
My 2013 535xi (built in August 2012) does not consume any oil between oil changes either, and like Surly73, I've been having my oil changed between 10K and 20K km intervals. I had my first oil change performed about 5K kms into the car's life, despite BMW service interval recommendations, too.
2010 Z4 35i, Crimson Red, beige interior, 6sp manual, Adapative Suspension 2000 528i, Cosmo Black, beige interior, Sport package (retired) |
02-13-2019, 09:35 AM | #4 |
Rep 79
I change my oil every 5k miles. I usually add about 2 qrts in between changes.
02-13-2019, 01:01 PM | #5 |
Rep 5,356
Neither of our N55's (2012 83K+ miles and 2014 48K miles) consume oil (as measured on the display) between the factory recommended oil changes; preformed at the dealer.
02-13-2019, 03:37 PM | #7 |
Rep 742
Drives: '13 F13 M6, '94 JDM Supra 5MT
2011 535xi purchased with 19k mi (30,000 km) and now has just under 40k mi (64000 km) and driven in a spirited manner with JB4 and only consumes a qt every 8000-9000 miles (1200-1500 km)
02-13-2019, 03:44 PM | #8 |
935
Rep 4,326
Drives: M340
Zero.... Its a 2016 with ~30K miles
2016 F10 535i xDrive - AW - Retired 2011 E92 M3 - AW……………....ED April 29th, 2010 - Retired 2007 E92 335i -Space Gray.....ED Oct 19th, 2006 - Retired |
02-13-2019, 03:55 PM | #9 |
Rep 79
Mine does have 95k miles on it, but still 1qrt every 2-3k miles is insane. Cannot be only turbo blow by, it most likely burns oil. Probably gotta rebuild the engine for that one...
02-14-2019, 02:17 PM | #10 | |
Rep 742
2013 F13 ///M6 Alpine White • Zandvoort Full Merino Driving Assistance Pkg • Exec Pkg • Vent Seats
Vorsteiner VFF-103 Carbon Graphite 343M dimensions • H&R Lowering Springs • Soul PP Resonated Muffler Delete • AeroFunction AF-1 Carbon Front Lip • Carbon Front Grilles • Carbon Mirror Caps • IND Black Fender Vents |
02-14-2019, 04:13 PM | #11 |
Rep 431
2011 535i with 72k miles. I run either Pentosin, or Motul oil in my car and almost 11k mile ownership of the car I have not had any oil consumption issues. My car is a MHD stage 2, VRSF CP, and ER catless dp. No issues!
02-14-2019, 11:54 PM | #12 |
Rep 342
It is going to depend how you drive it. If you are hard on it with lots of WOT to redline, it is going to use more oil... If you baby it, it is much less likely to use oil. I found this with both my n54 335i and n55 535i. If you baby it and it is using oil, you have other issues to investigate.
trialmountain53.50 |
02-15-2019, 09:37 AM | #13 |
Rep 915
I do 5k oil change intervals no oil consumed or lost always full. 91.5k miles 2011 535i xdrive. Even with WOT pulls when warm.
Instgram @burninja
02-16-2019, 06:42 AM | #16 |
Rep 2,195
2011 535i with 69k miles. I change oil at 7500 mile intervals and usually need to add 1 quart at around 5-6k miles. Running BMS Stage 1, BMS intake and M Perf exhaust.
Bake
goos0.00 |
