01-26-2019, 08:13 PM | #1 |
Rep 590
F10 Fault code help
Just today the check engine light came on and I ran tests using ISTA and got these
118001 - Mixture control mixture too lean 180001 - Catalytic Converter efficiency below limit value I have Cp, dp, m performance exhaust with bm3 stage 1 |
01-27-2019, 09:43 AM | #2 |
Rep 5,691
Catalytic converters effeciency- you took yours out so yes you will have that fault.
Mixture control too lean- you still need to smoke test your intake to find the leak since you installed your charge pipe. |
01-27-2019, 02:49 PM | #3 |
Rep 5,365
I would think the gutted cat would throw the lean code too...
01-27-2019, 04:28 PM | #4 |
Rep 590
01-27-2019, 09:51 PM | #5 |
Rep 5,691
01-27-2019, 09:58 PM | #7 |
Rep 5,691
01-27-2019, 11:04 PM | #9 |
Rep 455
Not likely. Your ECU is leaning out fuel mixture because O2s picking up above avg. HCs.
What precautions did you take? O2 bung extenders? Turn off O2s? You can't expect to bolt on a catless DP and expect nothing to happen??? Last edited by John H.; 01-27-2019 at 11:12 PM.. Reason: Added info. |
01-28-2019, 01:24 AM | #10 | |
Rep 590
01-28-2019, 10:45 AM | #11 |
Rep 455
Have you considered a tune? Based on reviews, Mission Performance seems hard to beat.
https://missiontuning.com/bmw-engine...are-flash.html Post your query in the Cali section. I'm sure a local member/s will make other suggestions. Last edited by John H.; 01-28-2019 at 10:48 AM.. Reason: Added info. |
01-28-2019, 12:26 PM | #12 | |
Rep 590
01-28-2019, 12:37 PM | #13 |
Rep 455
01-28-2019, 12:48 PM | #14 |
Rep 590
I did so I'm not sure why I still have a check engine light and go those codes maybe I should get my car smoked to see if I have any leaks my local shop wants $130
01-28-2019, 12:54 PM | #15 | |
Rep 455
I've been talking with another local via PM. Hit up jtrejo. He might be able to help with your diagnosis. Have a good one. |
