2010 2011 BMW 5 Series Forum F10 2011 535i base oil leak oil cooler |
12-01-2018, 12:30 PM | #2 |
Rep 5,366
12-01-2018, 12:45 PM | #3 | |
Rep 14
12-01-2018, 12:49 PM | #4 |
Rep 5,366
Looks like it to me. When I had that issue I also had oil pooling in the depressions by the cap. Yours looks like a more serious leak and I would take care of that before the oil contaminates the serpentine belt.
Taking a closer look at the pictures, it looks like the belt already has oil on it and is contaminated. While you're there, I would change that also and do a through clean-up of all the oil. |
12-01-2018, 08:58 PM | #5 | |
Rep 915
Instgram @burninja
12-01-2018, 09:38 PM | #6 |
Rep 1,214
Extremely common leak from the oil filter housing and oil cooler housing gaskets. Upper radiator hose, belt and tensioner should also be replaced.
Potentially the thermostat hose as well "mickey mouse" but that isn't clearly seen in your pictures. It also usually gets wasted from the oil contamination. |
12-01-2018, 10:07 PM | #7 | |
Rep 14
12-01-2018, 10:15 PM | #8 | |
Rep 590
12-01-2018, 10:39 PM | #9 |
Rep 5,366
12-09-2018, 09:52 AM | #10 | ||
Rep 14
Charging malfunction light came on Serpentine belt shredded.... was this because of the leak. Now what will need to be checked and replaced any input? I will Upload pics when I get home |
12-09-2018, 10:21 AM | #12 | ||
Rep 14
I put a napkin under to see if it's still leaking under nothing. |
12-09-2018, 10:24 AM | #13 | ||||
Rep 14
12-09-2018, 05:57 PM | #14 |
Rep 1,214
100% your failure to correct the issue in a timely manner just got a lot more expensive. The belt breaking is the normal failure that brings severely neglected leaking cars into the shop.
The correction now (beyond what I posted earlier) is pull the harmonic balancer and inspect/replace the crank seal. Drop the engine oil pan and remove belt material from the sump. Pick belt material out of the timing chain. Remove the oil pump pickup and flush belt debris from it. |
12-09-2018, 06:09 PM | #15 | |
Rep 14
12-10-2018, 02:27 PM | #16 |
Keepin' America Free
72
Rep 1,260
Sorry to hear man. I was coming here to say "fix it before your belt snaps". Sounds like I'm too late, best of luck OP.
F10 535i | Retired: E60 ///M5 | E92 335i
"If everything seems under control, you're not going fast enough" -Mario Andretti |
12-11-2018, 01:36 PM | #17 |
Rep 14
Thanks man. Got the parts at bmw today. Just need to take the harmonic balancer off and check the seal for leaks ... any one here taken one off ?
12-12-2018, 06:42 PM | #18 | |
Rep 14
12-12-2018, 08:48 PM | #20 |
Rep 14
This what was left
12-12-2018, 08:50 PM | #21 |
Rep 23
honestly if it shredded and you have the capability of pulling the pan I would. you dont want your oil pickup getting clogged or any material getting into places it shouldn't
12-12-2018, 08:52 PM | #22 |
Rep 14
I do have the capability of removing it the pan but what are the steps to it ? Do I have to replace the bolts to the pan ? but might as well do oil change also
