2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications F10 Fault code help
      01-26-2019, 08:13 PM   #1
jonobro
Drives: bmw f10 535i
F10 Fault code help
Just today the check engine light came on and I ran tests using ISTA and got these
118001 - Mixture control mixture too lean
180001 - Catalytic Converter efficiency below limit value
I have Cp, dp, m performance exhaust with bm3 stage 1
      01-27-2019, 09:43 AM   #2
NinetyEight740
NinetyEight740's Avatar
Drives: 2 - 2013 535i msport
2010 E91  [0.00]
Catalytic converters effeciency- you took yours out so yes you will have that fault.
Mixture control too lean- you still need to smoke test your intake to find the leak since you installed your charge pipe.
      01-27-2019, 02:49 PM   #3
I would think the gutted cat would throw the lean code too...
      01-27-2019, 04:28 PM   #4
jonobro
I didn't take mine out ?
      01-27-2019, 09:51 PM   #5
NinetyEight740
2010 E91  [0.00]
You put in a catless downpipe did you Not?
      01-27-2019, 09:52 PM   #6
jonobro
Yes
      01-27-2019, 09:58 PM   #7
NinetyEight740
2010 E91  [0.00]
Yes
Then you have no cat converter, that’s why you would have a catalytic converter efficiency fault
      01-27-2019, 10:53 PM   #8
jonobro
Yes
So I don't have a leak ?
O1NE0.00
      01-27-2019, 11:04 PM   #9
John H.
John H.'s Avatar
Drives: 2014 535i XDrive
Not likely. Your ECU is leaning out fuel mixture because O2s picking up above avg. HCs.
What precautions did you take? O2 bung extenders? Turn off O2s? You can't expect to bolt on a catless DP and expect nothing to happen???
      01-28-2019, 01:24 AM   #10
jonobro
What do you recommend I do ?
      01-28-2019, 10:45 AM   #11
John H.
John H.'s Avatar
Have you considered a tune? Based on reviews, Mission Performance seems hard to beat.
https://missiontuning.com/bmw-engine...are-flash.html
Post your query in the Cali section. I'm sure a local member/s will make other suggestions.
      01-28-2019, 12:26 PM   #12
jonobro
I have a tune bm3 stage 1
      01-28-2019, 12:37 PM   #13
John H.
John H.'s Avatar
My bad, for some reason, I thought you had a piggyback.
I am not familiar with BM3; however, there should be options to address the CEL issue.
      01-28-2019, 12:48 PM   #14
jonobro
I did so I'm not sure why I still have a check engine light and go those codes maybe I should get my car smoked to see if I have any leaks my local shop wants $130
      01-28-2019, 12:54 PM   #15
John H.
John H.'s Avatar
That's about right. Get someone that is familiar with BMW.
I've been talking with another local via PM. Hit up jtrejo. He might be able to help with your diagnosis.
Have a good one.
