2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums F10 / F11 5-Series Photos - Video - Media What did you do to your 5 series today?
      06-01-2025, 10:51 AM   #3741
zener
BMW enthusiast since 2004
844
Drives: E65 730d, F10 520d, E34 520i
Changed front right soft close motor and started to build LCW wiring harness. Next step is to take rear bumper off and run rest of the wires to car and then some coding to see if it works.
      06-02-2025, 09:41 AM   #3742
T-Dubbs
Coal Troll
231
Drives: '14 F10 535d
finally got around to getting my exhaust completed!
rear muffler delete and quad tips from a totaled 550i, then the diffuser is from ali express...(fitment sucked)
Might try and use an oem diffuser and add the diffuser fins in the middle if I can.. we will see!
My hybrid burns Diesel & Oil
deleted F15
NikMN4563.00
s_ribs136.00
      06-02-2025, 10:34 PM   #3743
JMc2018
Drives: 2014 535i M-sport 6spd Manual
May not be the most popular mod, but im a sucker for trying to clean things up while I'm already "in there".
Doing a VVT actuator on my '14 535i m sport w/6speed manual @115k miles. Ordered all new plugs, valve cover and hoses, etc. And figured a paint matched valve cover might clean up the engine bay a bit!
And yes, that is my downstairs bathroom that we are going to be renovating soon. So I turned it into a paint booth before we demo it all haha set up a blower from the outside vent to pull air out of the fart fan, worked out pretty well.
Got all the paint at my local oreillys, they can fill almost any factory paint code into to aerosol cans and they now stock a true 2k clear in a can as well with the popper on the bottom, turned out pretty sweet.
Used nitrile glove fingers to cover all hose holes and ear plugs to cover up all screw holes, taped the bolts over.
So here's my carbon black n55 valve cover before and after.
NikMN4563.00
s_ribs136.00
13-535i13.50
      06-03-2025, 05:46 AM   #3744
zener
844
Started routing the wires for the LCW. It's nearly done... Everything else is done but I still need run +12v wire and connect earth, then I can try to code it.
      06-03-2025, 07:42 AM   #3745
musclesmarinara75
musclesmarinara75's Avatar
Drives: 2013 BMW F10 N55 535i XDrive
2013 535 XDrive  [9.75]
I'm curious how that paint will last, I have used 2k clear in the can before... it's good stuff...only on engine covers,.. but it lasted so far... never did a valve cover...lets see pics after a few thousand miles
$ PURE STAGE 2 {} JORDAN CUSTOM TUNE {}TURNER CF INTAKE{}BURGER OCC{} DORCH HPFP {} SNOW 2.5 METH {} MPE EXHAUST {} EVOLV DARK OLIVE WRAP $
      06-03-2025, 12:27 PM   #3746
zener
844
Got all wiring done but can't get the 0x03 flexray port to open. With ISTA flexray init will finish fine but it won't open the port for SSW. It shows up red in ISTA and does not show up on E-SYS.
      06-04-2025, 05:26 AM   #3747
zener
844
Changed HC2 to different flexray port and got it online and coded to the car. Got wiring tucked in nicely and bumper back on.
Let's go for a test drive and it works, video: https://photos.app.goo.gl/bLEGyQQKetW6QrUY9
      06-05-2025, 08:42 PM   #3748
bk_mike
bk_mike's Avatar
Drives: F10 550ix
Grabbed a JBE and donor harness to retrofit the rear sunshade. Added bonus is tons of spare wire and the exact connectors I need to complete the job.
NikMN4563.00
      06-06-2025, 12:28 PM   #3749
zener
844
Replaced refurbed brake calipers all around with new brake hoses.
NikMN4563.00
s_ribs136.00
      06-07-2025, 08:30 PM   #3750
JonnyRock
JonnyRock's Avatar
56
Drives: '14 535d Msport
Trim blackout continues. Decided to try my hand at vinyl wrapping for the first time. Took a few tries and I ended up with probably a 6/10 job. I'll either try again another time or pick up some gloss ones in the near future but for now these will suffice.
NikMN4563.00
      06-12-2025, 10:04 AM   #3751
zener
844
Modified F40 frameless rear view mirror to fit in to prelci f10.
Used two small screws to hold the bigger ball in place and modified plastic surrounding the mirror.
      06-12-2025, 10:31 PM   #3752
13-535i
1&Only
13-535i's Avatar
14
Drives: 2013 BMW 535i
New downpipe came in today. I went to install it and one of my bolts snapped that attached it to a hanger so I was pretty much screwed cause I didn’t have the necessary tools to get it out. I brought it to a shop, they got it unstuck, got my old cat out and put in my vrsf catless downpipe. Honestly it sounds great. The spool is amazing as well is the sheer loudness of the car. Barely any drone surprisingly as well and I think because of the fact that I got new gaskets and clamps for the downpipe, it doesn’t smell at all inside the car, even at a stoplight with windows down! Super happy with how it turned out. Those burbles in between shifts is just great, it perfectly fits the turbo works mufflers I have installed.
Also I got it done earlier today and pretty much drove the rest of the day cause I couldn’t get over how good it sounded, I noticed a little bit of rattle, as if something was loose, but it seems to have gone away I think? Can’t really tell because it’s the first day but I’m assuming it just needs to settle. But aside from that, everything is great! Anddd, no cel yet either! I’m not tuned and I didn’t install any spacers so it’s great! I’m assuming it might come on it a bit but I drove quite a bit today and still no cel so we will see! Next step… chargepipe, tune and maybe something else.
I have something really big planned that I’m thinking of doing to my car that apparently only a handful of people have done to their f10 535i in terms of customization. I think it would be sick.. lmk if you’re interested in finding out what it is!
      06-13-2025, 09:43 AM   #3753
ctcarbonari
ctcarbonari's Avatar
Drives: 2015 BMW 535i M Sport
2015 BMW 535i  [0.00]
I'm interested. Let us know.
I hope it's a performance transmission upgrade!
If time and money were no object this is what I'd do on my (F10) 15' 535i
Now that would be sick.
https://www.puredrivetrainsolutions....ission-upgrade
      06-13-2025, 10:38 AM   #3754
Unspec
Unspec's Avatar
1504
Drives: 2015 BMW 535xi
Yea the bolts for the hangers of the DP looooooooove breaking. Pretty much require heat + penetrating oil if you don't want to break them.
It will likely throw a CEL soon, it takes a bit for the readiness checks to set and thus throw the CEL.
Honestly I have yet to see someone on the 5/6/7 platform do one of the pure transmission upgrades. It's just hilariously expensive.
2015 BMW 535xi
ISTA VM Setup/Tutorial
      06-16-2025, 10:50 AM   #3755
zener
844
Painted tail pipes gloss black. I have real black one's on order but they have not arrived yet.
      06-19-2025, 11:35 AM   #3756
lukavergille
lukavergille's Avatar
Georgia
238
Drives: BMW 535i F10
2013 BMW 535i  [9.50]
Has anyone tried installing CSL style carbon trunk on F10? I pulled a trigger and bought it yesterday, but not quite sure how it looks on the car (in my imagination it should look nice &#128064. If anyone has it please share some photos, will post mine once it arrives
      06-19-2025, 12:26 PM   #3757
zener
844
Front right wheel bearing replaced.
      06-19-2025, 07:17 PM   #3758
13-535i
1&Only
13-535i's Avatar
14
Did you install it yet? Curious how it looks
      06-20-2025, 12:30 PM   #3759
T-Dubbs
Coal Troll
231
I bought my car with a JR stg 2(deletes) tune on it.
Its been great with no issues, but I noticed that the power really seemed to drop off past 3rd gear... anyways talking to a different tuner, he suggested that do some data logs to see if there was something wrong..
Turns out I'm running close to stock boost in 4th gear.
I guess the problem lays with my altitude (3,430ft above sea level)... the JR tune doesnt adjust the maps for the elevation.
I ended up with another tune (DUDMD). Did some logs and finalized on a tune for my elevation.
The difference is NIGHT and DAY from the previous tune. I was not expecting to feel much of a difference for just switching software.
Big thumbs up for DUDMD for their N57 Tune!
deleted F15
      06-20-2025, 08:08 PM   #3760
bk_mike
bk_mike's Avatar
Drives: F10 550ix
Installed a new JBE, alcantara rear deck and motorized rear sunshade. Then time for a nice wash and vacum.
      06-21-2025, 04:46 AM   #3761
lukavergille
Georgia
238
Still waiting for delivery, it should be here in 2 weeks. Will post some pictures afterwards
      06-22-2025, 01:45 PM   #3762
F10GUY
F10GUY's Avatar
Drives: 2014 BMW 535dx Msport
Removed my crossbars the other day.
