09-30-2020, 09:52 AM | #1 |
Rep 41
Ambient light install
Hi all
Has anyone tried to install the 9/18 colour led kit and has been able to code the idrive to allow the changes of the colour ? See the example video My current car is on nbt, with the standard white and orange ambients lights £118.91 45% Off | PMFC 18 Colors Atmosphere Light LED Interior Decorative Ambient Door Light Stripes Lamp For BMW 5 Series F10/F11/F18 2010-2017 https://a.aliexpress.com/_mqtmtUr - this is an example of what I have been looking at if there is anything better which can do the same thing but can be control with the idrive let me know Harmeet |
11-18-2020, 03:06 PM | #2 |
Rep 8
Maybe check out this video: https://www.google.com/url?sa=t&rct=...2sus1fdvB65dom
11-22-2020, 02:27 PM | #3 |
Rep 17
I've been also eyeing this, the weird thing is on that listing and most others, they distinguish between NBT with a production date before and after September 2014. They say even with NBT before September, then go with the CIC that has a manual control. I'm just like you i have the white and amber through the iDrive. I'm Curious if which you end up going... I was going to simply get the CIC version and not worry about the iDrive interface.
GrabacrOne177.50 |
11-26-2020, 07:42 AM | #4 | |
Rep 41
Soo I have complete the install it was simple! You just need to extend some of the harness and you can use the blank pins within the door plug there is 4 of them for each side. Then you just need code the idrive it's one thing you need to do, but it works well I would recommend it updates the car a lot. Let me know if you want any more information |
11-26-2020, 12:40 PM | #5 | ||
Rep 17
11-30-2020, 05:20 AM | #6 | |||
Rep 41
02-22-2021, 11:27 PM | #7 | |
Rep 1,244
Drives: 2013 F10 M5
I've been looking at this one recently, https://www.aliexpress.com/item/1005...3ea42e0eiuXNfh |
02-23-2021, 01:34 PM | #8 |
Rep 36
i recently did this to mine you have to rewire all ambient light kit it comes with the harness it will take an entire day to do properly.
its a massive improvment over Stock versions and having more colours is so much better |
02-23-2021, 01:46 PM | #9 |
Rep 1,244
Drives: 2013 F10 M5
That's what I was wondering. I assumed that I'd have undo the existing harness and replace it.
02-23-2021, 01:48 PM | #10 |
Rep 36
no i left my original harness in the doors and just tapped it up out of the way just be carfull when putting the leds in the original bracks or you can knock the leds lose
02-23-2021, 04:46 PM | #11 | |
Rep 1,244
Drives: 2013 F10 M5
I'll probably go ahead and pull the trigger on ordering this kit, for ~$100 it's not a bad deal. |
03-08-2021, 09:43 AM | #13 | |
Rep 2
03-15-2021, 06:15 AM | #14 | ||||
Rep 41
Hi mate I don't use BimmerCode I do all my work using e-sys I can tell you the step in e-sys but You'll have to work out how to do it in BimmerCode |
03-17-2021, 09:47 AM | #15 | |
Rep 4
Hi Harmz! Correctly I understood that it is possible to change all 9 colors from idrive? May be is possible to send a link from which specific seller to buy good ambient light kit. I have read different opinions that some sellers are not so good as they describe their products |
03-20-2021, 03:17 AM | #16 | ||
Rep 41
This is the seller who I got it from, https://a.aliexpress.com/_mO590Z9 |
07-08-2021, 03:34 PM | #17 | |
Rep 6
Very very nice |
01-16-2022, 01:42 PM | #18 |
Rep 1
NBT Issues
Hi,
I was wondering if anyone had the same issue as me. I installed the 9 Color ambient light system on my f10 and coded the following on my NBT system. "COLOR_SWITCH - aktiv" "HELLIGKEIT_AMBLIGHT - aktiv" "COLOR_SWITCH_ENSEMBLE - 10_eintraege" After coding ambient lighting shows up on the headunit and i can select "Classic Mode" which give red and i can adjust the brightness. I cannot select any other colors as it does not give me the option, Has anyone had this issue? I also added "Modern" mode through "COLOR_SWITCH_LINES" Which gives me like a blue color. Also when i adjust the brightness the scroll bar does not update but the brightness still changes. Maybe i have forgotten to enable something? Thanks in advance |
