2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes G30 brake fit F10/11?
      08-24-2021, 07:01 AM   #1
stfoer
Drives: BMW F11
Anyone know if the G30 rear brake caliper fit the F10/11 with the 345x24mm disc? Thank you.
      08-24-2021, 06:17 PM   #2
addy27
Drives: F10 550i
Not quite, BUT, you can buy the M5 carrier and keep your current caliper and fit 370x24 from the F01 (High speed braking system) version.
      08-25-2021, 04:38 AM   #3
stfoer
Drives: BMW F11
Yes I know that, but I like the look of these new ones with the M-logo.
No one tried these ones?
      08-27-2021, 03:57 PM   #4
addy27
Drives: F10 550i
I believe there is a thread where it was tried but it does not sit correctly. as in vertical gap and angle where the pads would touch the rotor isn't correct.
      09-02-2021, 02:39 AM   #5
stfoer
Drives: BMW F11
I found a lot of info on the front, which fit using a 4mm spacer between caliper and hub. So far I have not been able to find anything for the rear. Do you have a link to that thread?
      11-02-2021, 08:37 AM   #6
stfoer
Drives: BMW F11
I can now confirm that the caliper carrier from the G30 DOES NOT fit the F10/11. The distance between the bolts are longer on the G30, so no way to fit them.
Now next will be to see if the G30 calipers will fit on the F10/11 carriers.
Stay tuned.
