2010 2011 BMW 5 Series Forum F10 Faulty crankshaft position sensor on new N63 motor. |
06-01-2019, 04:50 AM | #1 |
Rep 99
Had the N63 engine replaced on my car and from day one its been having issues starting. Same code every time, bad crankshaft position sensor. Already been changed out like 4 times. Its back at the shop and now they're working with the factory to figure it out.
I'm not a mechanic, but I dont think the issue is the sensor and changing them out hasn't solved anything. Engine will crank with no start, or will crank, start but be in DTM/reduced power mode. On the way to the shop the tachometer dropped out, said zero as the engine was still running. What could possibly be causing all these issues on a brand new motor? Before they replaced it, never had any issues with starting, engine purrd, minus the heavy oil consumption. |
06-01-2019, 11:12 AM | #2 |
Rep 175
Sounds like an electrical issue or grounding on the circuit. Make sure all connections are tight, clean and not broken. You might have to trace it to the dme and make sure the connection to the dme is also tight.
This is possible during engine replacement . |
