2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Delpho coil doesnt fit
      02-22-2020, 01:30 PM   #1
Rob09msport
Drives: 09 335 msport
Delphi newest revision from fcp doesnt fit n63tu I know people have said shorter but I believe that is ok, my problem is the connector has a fin in center on the Delphi so my harnesses couldnt attach I had to slice my harness
      02-24-2020, 05:57 AM   #2
Rob09msport
Gn10328 is proper coil the gn10571 dont fit properly and cause misfires. Hopefully this saves someone 300 dollars if they have a mid 2015 build or newer . We use same coils as m5 m6 and m550i according to realoem . It's almost like a hybrid n63tu n63tu2 engine
      03-08-2020, 11:08 PM   #3
zcali925
zcali925's Avatar
Drives: '15 BMW 535i M Sport
I don't see the part references you mention anywhere on realoem for the ignition system.
Sup
      03-13-2020, 09:01 AM   #4
Rob09msport
Those are the delphi part numbers realoem lists bmw part number. You have to cross reference
