2010 2011 BMW 5 Series Forum F10 Performance coils for n63 |
01-05-2021, 12:07 AM | #1 |
Cole
319
Rep 498
I was just wondering if any n63 owners have installed the red performance coils?
I ordered a set and will be trying them out, primarily hoping they last longer than the bosch and provide a smoother idle. |
01-05-2021, 10:23 AM | #3 |
Cole
319
Rep 498
01-05-2021, 10:57 AM | #4 | |
Rep 2,587
https://www.turnermotorsport.com/p-5...l-priced-each/ Your link just goes to a search results page.
2015 BMW 535xi
01-05-2021, 09:48 PM | #6 |
Rep 262
I have these installed on my N63, made my car run a lot better with 2 step colder NGK and JB4. I think it was worth the extra cost
2011 550i (N63)
Upgraded 51mm turbos, Heatsync Stage 3 Flash, JB4 stacked, BMS WMI, Arm Charge Pipes, Heatsync Catless DPs, X-Pipe, Res Muffler Delete, xHP Stage 3 Trans Flash, Turbosmart Diverter Valves, 3.5 TMAPs, Oil Cooler, Heatsync Front Mounted Max Cool Intakes, Walbro LPFP and e40 mix rollin on Stance SF07 9x20 w/Toyo Extensa and 10.5x20 w/Toyo R888R. |
01-06-2021, 11:28 PM | #7 | |
Cole
319
Rep 498
My plugs were replaced when the engine was replaced about 10k miles ago so I didnt order new plugs. Do I need to use a colder plug with the coils? Changing them at a later time isn't a problem to me because it really is easy to swap plugs. |
01-06-2021, 11:48 PM | #8 | ||
Rep 262
2011 550i (N63)
01-07-2021, 02:36 PM | #9 |
Cole
319
Rep 498
I took your advice and ordered the same NGK plugs. Figured, I have two bad injectors and they must of fouled at least one of the plugs(pulled one and it was solid black) so I am better off changing them too.
Thanks, |
