2010 2011 BMW 5 Series Forum F10 BIMMERPOST Universal Forums Professional Motorsport Racing Discussion (IMSA, DTM, Formula 1, Grand-AM, Le Mans, IRL, WRC, etc..) cool paper on BMW F1 engines
      07-28-2021, 10:11 AM   #1
Chihuahua
Chihuahua's Avatar
4075
Drives: E30 329iS, E65 Alpina B7
Thought some people might get a kick out of reading this, it was written by Super Mario several years ago. I came across it last night. It's an interesting read for F1 fans that geek out on the technical side of things.
http://sd-2.archive-host.com/membres...urs_BMW_F1.pdf
Appreciate 10
prompt292.00
Bubbles2753.00
overcoil3073.50
EdM54064.50
Atavus74.50
MontyB11395.00
      09-14-2021, 08:07 AM   #2
charlie_m
Drives: 2012 328ix
Thanks for this! I can't imagine designing things to run for a certain number of *hours*; it's a fine line between long engine life and catastrophic failure.
      09-14-2021, 09:13 AM   #3
Bongoxxx
Drives: 2018 340 XDrive
Interesting read, thanks for sharing!
Current: 2023 Volvo XC60 B6 Ultimate Thunder Grey on Blonde Polestar Enhanced
Previous: 2018 340 xDrive M-Sport Mineral Grey
Previous: 2016 328 xDrive Alpine White
      09-14-2021, 04:55 PM   #4
overcoil
Drives: M235i 6spd
what is BANK OFFSET ? centerline difference in millimeters between left and right bank ?
      09-14-2021, 05:10 PM   #5
Lurch1989
Drives: 420D
Thanks, will take a read of this.
I did used to work for a manufacturer that made things to a certain life span, certainly was difficult to get the fine line
      09-14-2021, 05:14 PM   #6
GuidoK
#buildnotbought
GuidoK's Avatar
10841
Drives: Z4 3.0i ESS TS2+
You can see one of these engines on display in the BMW museum in Munich.
Really intereresting, it's way smaller than you'd expect (than I expected at least).
All the connectors, barb fittings etc are also really small, way smaller than normal automotive connectors etc. Obviously to save weight, but it gives a bit the impression that it's a model scale engine
The clutch is also pretty interesting.
M5Rick60013.50
      09-15-2021, 08:12 PM   #7
charlie_m
Drives: 2012 328ix
Yes, so the rods can stay on the centerline of the piston / cylinder bore, with the big end of the rods on a shared-journal crankshaft. So essentially bank offset also gives you width of the big ends of the rods.
Not to be confused with the so-called DeSaxe layout, where the bore centerlines are slightly offset (they don't point directly to the crankshaft axis).
At least that is my understanding.
MKSixer34184.50
overcoil3073.50
      09-16-2021, 08:12 AM   #8
MKSixer
MKSixer's Avatar
34185
Drives: 2015 BMW i8, E63 M6, 328d
2016 M4 GTS (Allotted)  [0.00]
2013 BMW 328d  [0.00]
2007 BMW M6  [10.00]
2015 BMW i8  [10.00]
Great article! Thanks for sharing!!
Several actors have played James Bond, Sean Connery IS James Bond...
Sir 7ewis, 7X FIA Formula One World Championship, World Driving Champion. 100 Wins. 101 Pole Positions. 54 Fastest Laps. Actual Rain Master. Leave me to it, Bono. One Race Win in each of his 15 years in F1. Most Laps Led in Formula One. The Centurion.
      09-16-2021, 09:31 AM   #9
Chihuahua
Chihuahua's Avatar
4075
Sure is! I miss the "Kblammo!!!" V10 Formula 1 days...
MKSixer34184.50
      09-16-2021, 09:38 AM   #10
MKSixer
MKSixer's Avatar
34185
2007 BMW M6  [10.00]
2015 BMW i8  [10.00]
Don't forget the metallic confetti when the seamless shift transmissions were introduced!! The first real glitter bombs!!
      12-04-2021, 09:44 PM   #11
qqcoding
Drives: 2016 640i Conv 2007 328i Conv
F1
Very interesting article.
      12-22-2021, 02:46 AM   #12
zeltragh
Drives: BMW E87
Very interesting , thank you !
      12-26-2021, 11:26 PM   #13
HypoxicWaiter
Drives: BMW M135i
Fantastic read! Thanks
