2010 2011 BMW 5 Series Forum F10 Has anyone installed NBT in Pre Lci with Bimmerretrofit adapter? (SOLVED) |
09-03-2018, 01:32 PM | #1 |
Rep 59
I'm installing a Nbt unit in my 530D F11 Pre Lci using Bimmerretrofit's Pre Lci adapter.
I have installed Everything, but according to manual i have to do the coding with direct connecting to the NBT unit via DIAGADDR63, i have spoken to the Bimmerretrofit support and they told me to connect the Enet Cable and Computer to a Router to obtain the DIAGADDR63 ip adress, i have a Asus Rt-AC66U laying around which i tried to connect but the DIAGADDR63 doesn't show up in the Client list, can someone help me here? Last edited by HaugF30; 09-10-2018 at 06:48 AM.. |
09-08-2018, 09:28 PM | #2 |
Rep 5
I used their pre-LCI NBT EVO adapter. I installed into F10 and did the same coding. It is simple, just plug enet lan cable to obdII port and to router. My is Linksys wrt54. You will see that address diagadres 63 and 62. Connect to adr63 with Esys. Code it with their instructions. If you need help drop me a line here. Bimerretrofit support offered me to code my NBT EVO but it turned out that I've completed it on my own before scheduled date for coding. Another thing about coding is to use fa file with vin of headunit. I heard Evo can lock if wrong VIN is i fa file.
09-09-2018, 03:40 AM | #3 |
Rep 59
I did a direct connect to it withouth a router, with gateway Connection to 169.254.199.99:6801 got a error code, same as with router that it couldnt connect but some functions could be coded still.
I can write Fa to the Nbt unit, but can't Reading it from the unit, i can Also code FDL. Now om trying to get my rearview camera to work. Last edited by HaugF30; 09-09-2018 at 03:42 AM.. Reason: Mispelled |
09-09-2018, 05:28 AM | #4 |
Rep 59
I have coded this for the rearview camera:
HU_NBT > EXBOX 3001 > AUX1_IN_HU = wert_255 [Default] HU_NBT > EXBOX 3001 > CAMERA_SYSTEM = trsvc HU_NBT > EXBOX 3001 > MACRO_RV_C = aktiv HU_NBT > EXBOX 3001 > TRSVC = wert_42 I got a image then i put in reverse but it is distorted. The second time i tried to go in reverse it didn't even switch on the CID. |
