2010 2011 BMW 5 Series Forum F10 What did you do to your 5 series today? |
04-29-2023, 09:22 PM | #2817 |
Rep 504
Drives: 2013 BMW F10 N55 535i XDrive
.. Iknow I really liked em' just the reverse lights, signal and hazards... no brake or running lights..
$ PURE STAGE 2 {} JORDAN CUSTOM TUNE {} DORCH HPFP {} SNOW METH {} DINAN EXHAUST {} EVOLV DARK OLIVE WRAP $
04-30-2023, 11:17 AM | #2818 |
Rep 251
Do those bumper wingz help with chips like mudflaps?
05-01-2023, 07:19 PM | #2820 |
Rep 332
Installed the Rennline phone mount! Loving it so far!
05-03-2023, 04:26 PM | #2821 |
Rep 251
Wonder Wheel came today, ceramic coated my wheels hopefully i can get on lift soon
05-04-2023, 07:26 AM | #2824 |
Rep 332
Very simple, just pull the trim, take out one bolt and put it through the mount. I also attached some felt where it (the metal part) contacts the trim so it does not scratch it or rattles. If you have a big phone (mine is a Note 20 Ultra), attach the plate lower on the phone since it will run into the air vent. Then you can adjust the mount to your linking. Also got some extra plates from Amazon for future use.
ctcarbonari292.00 |
05-04-2023, 09:13 AM | #2825 |
Rep 233
Drives: 2015 BMW 535i M Sport
Finally got around to installing the M Pedals I received over the holidays.
Drilling holes in the Bimmer was fun! Although I prolly should have taken the pic AFTER I vacummed up the metal shavings. lol |
zvery777271.00 |
05-08-2023, 02:02 PM | #2826 |
Rep 251
05-09-2023, 06:03 AM | #2827 |
Rep 504
With my Dinan pedals had to drill pilot holes, the is no way you are using self taping screws lol, that's some hard thick steel on that brake pedal, they attached with nuts and bolts
05-09-2023, 06:11 AM | #2828 |
Rep 251
05-09-2023, 06:21 AM | #2829 |
Rep 504
Just ordered mine
zvery777271.00 |
05-09-2023, 06:22 AM | #2830 |
Rep 504
That is plastic, you drill a small pilot and use regular screws if I'm not mistaken
05-09-2023, 07:28 AM | #2831 |
Rep 251
I gotcha, just curious thought you got a nut back there some how. But i want to try get something like a plate so i can get bolts in becase i want allenhead instead of jus screws
05-14-2023, 08:17 PM | #2832 | |
Rep 2,995
Drives: 2006 BMW 330i MT
Garage List 2006 BMW 330i [8.21]
2009 BMW 328i Touri ... [7.90] 2013 BMW X5 35i [7.63] 2011 BMW 528i [8.75] 2006 Mazda3 [5.50] |
FYI you can buy black out reflectors for the bumpers if you haven't looked into those yet. |
musclesmarinara75206.00 ctcarbonari292.00 |
05-19-2023, 01:15 AM | #2834 |
Rep 233
For the BMW M Pedals, they attach as follows:
Accelerator pedal are self tappers. Gotta drill pilot holes into the plastic pedal. Then there is also a "full faced" adhesive strip. Brake pedal is nuts & bolts. Drilling thru the metal brake can be a little tricky to make sure your marks line up as pedal is not flat but curved a bit (and a couple of the holes are very close to the edge, imo). I used a small bit to make pilot hole starters then reamed them out with full sized bit required. Very tight and cramped space to get the tiny nuts started on the threads. I had to hold the nut flush with one finger while driving the bolt with a rachet. Then used needle nose pliers to get a bite and hold when tightening down. |
Double Nickel165.00 |
05-20-2023, 09:44 PM | #2835 |
Rep 332
Wrapped my side markers in gloss black!
ctcarbonari292.00 StradaRedlands4939.00 |
05-23-2023, 05:32 PM | #2837 |
Rep 251
Got my calipers and ss lines and my wheels on today but i didnt get a shot at my rear insert
05-25-2023, 02:44 PM | #2838 |
Rep 179
Drives: BMW 535i F10
Finished installing the yellow DRLs.
Trying to properly take the picture of the angel lights at night but when angels are visible everything else is dark |
Dtex535101.00 StradaRedlands4939.00 |
