2010 2011 BMW 5 Series Forum F10 HELP 2011 535i transmission issue |
09-03-2020, 07:38 AM | #23 |
Rep 1,873
I bookmarked that link right away, but hope to never need it
09-04-2020, 11:54 AM | #25 |
Rep 68
Drives: 2011 535ix M-sport
Sounds like the previous owner lied about changing the fluid right before selling it. The fluid will always appear black when drained, just how dark black and how much the green hue can be seen is how to judge it.
'11 535ix M-Sport - FMIC, CP, BM3 engine & trans, CQuartz Finest Ceramic, Poly tension bushings, Dynamic, Active Roll, Flappy paddles, HUD, Premium(s), Cold, Convenience, 5-cameras, 4-zones, Driver's Assist, Auto high, Hex trim
'92 850i, '08 XC90 3.2 Past: '93 525i w/ S38B36 M5 engine/trans swap, '99 540i/6sp Sport, etc. |
09-04-2020, 12:51 PM | #26 | |
Rep 1,873
The metal shavings bit doesn't sound good. Any evidence based on date stamps whether the pan was changed? The filter is integrated into the pan, of course, and is a key part of keeping things working properly. |
09-04-2020, 07:10 PM | #27 | |
Rep 68
09-14-2020, 09:59 AM | #28 |
Rep 38
Thanks everyone for the help Got the car up and running this weekend. Ended up replacing all the solenoids and fluid. Figured might as well do them all while in there even if it was just the one. Does anyone know if these things can be rebuilt? Might be worth keeping the old ones around if so.
09-15-2020, 07:24 AM | #29 | |
Rep 1,873
09-15-2020, 08:24 AM | #30 |
Rep 38
09-15-2020, 11:44 AM | #31 | |
Rep 1,873
Glad to hear about the improvement, and you did it yourself I assume? It would be interesting to know what you found etc... |
09-15-2020, 12:46 PM | #33 |
Rep 38
Yea i ended up doing it myself and I'm glad i did. I had never actually done a trans flush on my own. So it was good to see it wasn't that difficult. Taking out the valve body was also fairly straight forward. And there is definitely a good amount more fluid swapped when dropping it.
09-15-2020, 12:50 PM | #34 |
Rep 38
I ended up getting a whole valve body with solenoids on eBay. Seller claimed it was entirely rebuilt. I was skeptical but took the chance as i had no other options. Buying just the solenoids seemed to not be available. My problem seemed to only be one solenoid, but i had it out so why not swap them all. I would have swapped in the whole valve body but read somewhere that required some coding.
