04-05-2019, 06:54 AM | #1 |
Rep 123
Do your own Maintenance
I know there are alot of videos on maintenance that are great to watch, but here are the sources to do it like the dealer.
Check FPCeuro dot com for BMW and OE manufacturer parts. Great site for maintenance manuals is https://www.newtis.info/. Part diagrams by Vin # check www.realoem dot com. With these three site you can do almost anything on your car. I have done powerstop performance brakes, oil filter housing gasket, tranny oil change, engine oil change (every 10K) spark plugs, custom intake, etc. Planning belt drive, water pump, thermostat, coolant change now. I am at 90K miles, I do not believe the lifetime fluid crap. I run the increase intake with a Burger stage 1 for a little more power. I think doing it yourself is about a 60% savings, sort of rewarding as well getting to know your car. |
04-05-2019, 09:28 AM | #2 | |
Rep 915
Instgram @burninja
04-06-2019, 12:49 AM | #3 |
Rep 14,522
you should post this in the DIY section for those wanting to DIY
04-07-2019, 06:42 AM | #5 |
Rep 123
I filled it until it came out the fill hole, at the temp range using a laser thermometer. Bought a cheap garden sprayer, cut the nozzle off, and heat formed the plastic tube to a right angle. This made filling easy. I also did a double fill to flush the converter.
07-01-2019, 09:05 PM | #6 |
Rep 68
Drives: 2013 F10 535I / Lime Rock M3
Great information thank you
07-02-2019, 01:09 AM | #7 | |
Rep 590
