2010 2011 BMW 5 Series Forum F10 F10 523i low pressure help |
06-09-2019, 06:35 AM | #1 |
Rep 7
Hello all
Recently my car (F10 523i 2011) is a bit sick and needs a lot of antention. The BIG issue is low pressure in high pressure rail. Under 140bar to be exact. It is N53B30A engine and i know about issues with HPFP, but i realy hope it is not the case for me. Mostly when i search around there are much more severe issues than my car developed Here are some points from last 1-2 months -car starts OK when cold, but occasionally i get a little bit longer crank time (less tha 2sec) when engine gets hotter (70 celsius and above) -no problem when engine is cold -no problem in sport mode (pressure still drops realy low, but no error -idle is a tiny bit shaky, but rev stands still without drops -hpfp pressure test OK and holds pressure without any issues -checked all injectors, one was dead (leak) other were cleaned and tested OK -can accelerate with cruise control without issues -if i dont accelerate too much (stay bellow 25% throttle, or accelerate in short taps) no errors situation when error occurs: -oil temp above 90 -transmision in normal mode -press and hold accelerator above ~25% for more than 10-15sec after drivetrain error pops up: -cooling spools upt to 100% cooling down the engine deeply below 90 degrees celsius -LPFP goes to 100% PWM -slight increase in consumption -ride quality unchanged (acceleration is as before) Last resort for me is HPFP. At least from my (small) knowledge. Any help would be realy helpfull |
