2010 2011 BMW 5 Series Forum F10 Heeeeeelp....Addding 6F FSC sat radio |
05-14-2019, 10:11 PM | #1 |
Rep 3
Not that i really even mind paying to have someone do for me, but i reeally like doing it myself for the experience...
I purchased 6F FSC code to add sat radio option to my NBT_HU on my 2015 F 10 Here are the steps i followed, but i still do not see the SAT radio option. What am i missing?:mad02 60: AlSO: I received 4 files D626xxx_006F0001.der D626xxx_006F0001.fsc D626xxx_006F0001.xml FSC_D626xxx_006F0001.fsc Link to Screenshot from e-sys https://www.dropbox.com/s/coq5u0zfcsj5nq8/6f.JPG?dl=0 When you got your SAT Radio FSC Code, you should received 3 files: e.g. xxxxxxx_006F0001.xml e.g. xxxxxxx_006F0001.der (FSC Code Certificate) e.g. xxxxxxx_006F0001.fsc (FSC Code) E-Sys => Options => Settings => FSC Tab => Certificate Field: Load FSC Code Certificate (e.g. xxxxxxx_006F0001.der) E-Sys => Comfort Mode => FSC => FSC Field: Load FSC Code (e.g. xxxxxxx_006F0001.fsc. The FSC Code file must first be Base 64 Decoded or else E-Sys can not read it. (Use B64Dec for Decoding - http://4mhz.de/b64dec.html). FA Field: Select "Read FA" to use cars current VO. Parameter Fields: (Example for Sat Radio FSC Code and CIC): Diagnostic Address (hex) = 63 (99 in Decimal for HU_CIC; I think the same for HU_NBT) Application Number (dec) = 111 (6F in Hexidecimal - In FSC File Name, e.g xxxxxxx_006F0001.fsc) Base Variant = HU_CIC (CIC module name, e.g. HU_CIC, HU_NBT, etc.) Upgrade Index = 1 (In FSC File Name, e.g xxxxxxx_006F0001.fsc)) Select "Upgrade FSC" to Import and Activate FSC Code. Select "Check FSC Status", and you should see: ---------- AppID 111 UpgradeIndex 1 SWTType SWTclassic full Last edited by pmunks; 05-14-2019 at 10:39 PM.. Reason: missing img |
