2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum 2015 Adaptive LCI LED Headlights Upgrade
      08-16-2019, 02:40 PM   #111
addy27
Drives: F10 550i
You are a lifesaver!!!
It says FRM3 on my module but it seems that i need to exchange it.. Its just about 200$ for a used one so compared to the headlights its not so expensive
Oh, forgot.. And the connectors? Do I need to exchange them aswell?
By Connectors I really mean both pins AND connectors IF you are creating your own harness. Else you only need the correct pins, some for behind the the fuse boxes, and the others for plugging into open locations on the modules. There is a thread on the M5 forum by "dima" who has successfully done this on an LCI M5 which details how he made the connections. I have pre LCI so I need more connections to be switched at the headlights, hence I opted for adding a new harness
https://f10.m5post.com/forums/showthread.php?t=1491367
      08-20-2019, 02:59 AM   #112
marclind
Drives: F11 520d 2011
addy27, this is the most usefull info anyone has ever given me in this forum. You are a real hero
      08-20-2019, 03:22 PM   #113
addy27
Drives: F10 550i
Glad to be of help, feel free to ask more questions. I will try to fully install the new harness this weekend. It's in the car already meaning going from fuse box to the firewall under the carpet. I haven't yet made the needed hole and push the harness through rubber grommet that shrouds the harness as it goes out from driver side inside to the outside of the car. And for the passenger side I need to remove the blower motor cover to get the harness through since the HVAC structure is in the way. Then, once I've made sure of continuity, I can test the new lights without having to remove the existing ones just to make sure things work. Then it would be the bumper removal and swap. (If all goes well &#128514
      08-21-2019, 07:00 AM   #114
marclind
Would appriciate if you can snap some photos and maybe email me or something. The guy who helps me said that no extra cables is needed. Just two CAN cables and something about LIN cables
He told me that LED uses less pins of all optional headlights. I have xenon pre-LCI on mine without adaptive steering, but I,ve bought a interior mirror for a car that has highbeam assistance so iŽll prepare for that upgrade while im doing this.
Highbeam assistance should be controlled by the FRM 3 if ive got this right?
My email is my username @Hotmail.com
      08-22-2019, 06:22 PM   #115
addy27
Drives: F10 550i
Glad to be of help, feel free to ask more questions. I will try to fully install the new harness this weekend. It's in the car already meaning going from fuse box to the firewall under the carpet. I haven't yet made the needed hole and push the harness through rubber grommet that shrouds the harness as it goes out from driver side inside to the outside of the car. And for the passenger side I need to remove the blower motor cover to get the harness through since the HVAC structure is in the way. Then, once I've made sure of continuity, I can test the new lights without having to remove the existing ones just to make sure things work. Then it would be the bumper removal and swap. (If all goes well ��)
LED headlights use 8 connections each total. There is DEFINITELY need to add at least 1 if not 2 power cables from the fuse boxes. Otherwise, it's essentially getting all the power from the FRM, which I'm not sure is capable of a full LED load (I could be wrong). Yes you need CAN3 lines from ZGW to headlights and lastly Lin connections to be moved around. It can be done using existing cables but that is a one way road since once you have them in, it would be very hard to go back to stock for any reason. My plan is I at least want to keep that option open hence adding the additional harness.
I had put together a diagram of all the wiring here: https://f10.5post.com/forums/showthr...LED+headlights
      08-22-2019, 11:06 PM   #116
rkstar9
Drives: '10 X5 3.5D
He told me that LED uses less pins of all optional headlights. I have xenon pre-LCI on mine without adaptive steering, but I,ve bought a interior mirror for a car that has highbeam assistance so i´ll prepare for that upgrade while im doing this.
speaking of FRM load. since they fry easily when moisture gets anywhere, could one add a fuse between frm and headlight. ?
talking about the data cable that comunicates frm with headlight modules stm and stml
535D Xdrive DUDMD Stage 1
x5d e70 DUDMD stage 2 tune
      08-23-2019, 10:16 AM   #117
addy27
Drives: F10 550i
You could, but ideally you want power from fuse box and communication signals (LIN)from the FRM.
      09-16-2021, 01:33 AM   #118
Spid3r
Drives: BMW 520d
Originally Posted by Archiebabes View Post
Installed my 2015 LCI LED Headlights upgrade on my 2011 F10
I will post more pictures when it is all coded and working.
Huge difference!
