2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums F10 / F11 5-Series Photos - Video - Media What did you do to your 5 series today?
      02-27-2020, 10:52 PM   #1585
AZ535i
AZ535i's Avatar
Drives: F10 535i
2013 BMW 535i  [0.00]
Hey Turbo, I think the new tips look great. My personal opinion, the tips should just slightly poke out of the diffuser. Good luck with yet another mod to your never ending project
      02-28-2020, 11:58 AM   #1586
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
Slightly like an inch maybe? You know because the tips just clamp on I'll probably take several pictures at different lengths and see what everyone thinks is good. Yea. Projects seem never ending lol
      02-28-2020, 01:56 PM   #1587
AZ535i
AZ535i's Avatar
Drives: F10 535i
I think snapping a couple of different placements of them installed maybe the your best bet. Sending them and posting them. I'm certain you'll get feedback. Who knows, you may find your preferred placement after looking at the various photos yourself.
Good luck man!
      02-28-2020, 03:29 PM   #1588
pabusky
pabusky's Avatar
242
Drives: 2022 M3
2022 BMW M3  [0.00]
No matter what color, nothing beats a clean car
Ulisse37.00
Ickdeep5720.50
      02-29-2020, 09:52 AM   #1589
Ickdeep
Ickdeep's Avatar
2015 BMW X5  [10.00]
2013 BMW M5 [SOLD]  [10.00]
2013 BMW 535i [SOLD]  [10.00]
I have mine stick out just a little. It was sticking out more before but I went back to the shop and get it fixed. Didn't wanna burn my legs while walking around it
benacto348.00
      02-29-2020, 02:40 PM   #1590
ramman434
Drives: F30 335i
Finally washed the car since November and popped on some CF M4 style mirror caps
'16 Carbon Black Metallic F10 535i M-Sport - TOTALED 11/21/21
'13 Black Sapphire Metallic F30 335i M-Sport - unknown charge pipe, MSport Exhaust, 20" 405M wheels, $61k MSRP, CF M4 Mirror caps & Spoiler, NGK plugs, Dinan Coils, BMS intake
Ickdeep5720.50
      02-29-2020, 02:58 PM   #1591
lsturbointeg
that actually looks perfect to me Ick!
      02-29-2020, 03:46 PM   #1592
Encendido3
Encendido3's Avatar
Drives: 2016 535i M Sport
Getting a light polish and wax done today. Previous owner let water spots SIT for lord knows how long
Ickdeep5720.50
      02-29-2020, 03:49 PM   #1593
lsturbointeg
looking good
      02-29-2020, 03:52 PM   #1594
lsturbointeg
just ordered the Vibrant 11619 j style o2 sensor to hopefully prevent the CEL coming on when i install the Catless VRSP dp in.
      03-04-2020, 01:59 PM   #1595
fletchf
Drives: 2012 550i
Oil change, washed it, added 12mm rear wheel spacers. Still need to lower it and do a paint correction.
Ickdeep5720.50
      03-14-2020, 07:57 AM   #1596
lsturbointeg
Currently changing the oil using LIQUI MOLY MFC, oil filter housing gasket, oil cooler gasket and belt all installed courtesy of Burrninja himself! everything ordered from ECS Tuning. comes to find out it looks like my Indy mechanic never actually changed out my oil filter housing gasket 2 years ago by looking at the gasket as it was pretty hard and not soft? we're suspecting he changed the oil cooler gasket instead as it still looked new. pretty ridiculous if you ask me! anyways, gonna use some simple green to scrub out all the oil cake build up on the motor where all the pulleys are with a wire brush. also gonna remove the cover underneath that protects the engine since it's been drenched in oil!
also my 4" tips came in! can't wait to get these on
Ickdeep5720.50
BurrNinja430.50
fletchf69.50
Gjohnson7255.00
      03-17-2020, 07:11 AM   #1597
lsturbointeg
been busy that last couple of days just cleaning up all the oil sludge that was left on the motor when i had the oil filter gasket housing replaced. as most of you know when it leaks it drips onto the belt which than flings all over everything. Much cleaner now!
Ickdeep5720.50
Gjohnson7255.00
      03-17-2020, 07:21 AM   #1598
lsturbointeg
what a PITA LOL! so because the gyms are now closed in Ohio i decided to put my energy into installing the VRSF catless dp. so there were quite a few issues i ran into. the 2nd nut bracket was really hard to get off because of how much room there was to work with. i eventually got it off but it did take some time. the 2nd was no matter what i do there just wasn't enough room to get the dp off with the exhaust still on. so that was the 3rd issue was removing the whole exhaust system including removing the lower brace bracket. once the exhaust was dropped it was just a matter of wiggling off the dp.
here she is flying high!
exhaust is down
and here's the OEM dp!
will post more progress pictures when i start reinstalling everything
fletchf69.50
Ickdeep5720.50
      03-18-2020, 07:37 AM   #1599
lsturbointeg
alright, got the Vibrant defouler installed along with all the OEM o2 sensors. per discussion in the Vibrant defouler thread i used the middle size restrictor and i have it facing upward as recommended. hope this helps other people interested in doing this as i couldn't find any info on which defouler to use which restrictor to use and the fact it needs to face up!
so after everything was installed i'm happy to report there's no CEL!!!!!!
just in case someone is researching i attached the link regarding the Vibrant defouler
https://f10.5post.com/forums/showthread.php?t=1698863
thanks to top ramen for the info on restrictor size during his research
and thanks to ziekxq for info regarding which way the vibrant faces and which 02 sensor it's to be installed on
fletchf69.50
      03-18-2020, 10:56 AM   #1600
fletchf
Drives: 2012 550i
Working from home a few weeks, need to go out and hook up the battery tender.
      03-18-2020, 06:55 PM   #1601
asian
Drives: F11 535i
Awesome! I'm waiting for mine to come. Are these replacement caps or cover caps that just stick on?
      03-18-2020, 10:29 PM   #1602
top ramen
Drives: Schwarz II 535i
Nice. Please post up some sound clips.
      03-19-2020, 07:01 AM   #1603
lsturbointeg
will do
      03-21-2020, 04:09 PM   #1604
zcali925
zcali925's Avatar
Drives: '15 BMW 535i M Sport
got a quick wash in before the rain and installed the new trunk spoiler.
Sup
      03-22-2020, 11:03 AM   #1605
ramman434
Drives: F30 335i
Yeah I just used some plastic trim tools and popped them off. Took me under 3 min to do both covers and they look great. My wife says my car looks like the bat mobile lol.
Installed a K&N drop in just now. Looks like my cars filter hadn't been replaced in more than 20k mi. I'm at 65k now after having put 4K on.
      03-22-2020, 12:45 PM   #1606
paul223
paul223's Avatar
Drives: F10
Just installed Dorch HPFP, Cary Jordan custom tune installed, Monica is beast!
