05-29-2020, 02:19 PM | #265 |
Rep 104
I changed my wastegate settings many times, but it seems like it did not really do anything. Tightening it only just cause more overboosting. Loosening it causes underboosting. So now I have it at about 7" of vacuum. I think recommended is 6-6.5"?
PS2, Wagner FMIC, XDi-60, Fuel-It! Stage 2 LPFP, Mperformance Mufflers, BM3
05-29-2020, 03:01 PM | #266 | |
Rep 517
BPM Tuned, Advanced Fuel Dynamics, Paddoq Valved Exhaust, Paddoq Magnetic Paddles, EDC dampers, Dinan Springs, H&R Sway. DCT all day long.
https://www.youtube.com/channel/UCFu...fWjCtOz49FDMlg |
05-29-2020, 03:43 PM | #267 |
Rep 104
It seems normal. All my logs are at 7". I have not touched it since moving to new tuner.
05-29-2020, 04:57 PM | #268 | |
Rep 1,230
N55 GENERAL
David Shoup Tuned Fully Built By Miami Engines/Project Motorworks Precision 6266 On Steroids |
Bmwdoubles_194.00 |
05-29-2020, 05:03 PM | #269 |
Rep 104
Nice! That's a full second faster than my best time! I'm glad to hear someone broke into the 11s. I did 12.4s when I was making 15 psi at 6K and tapering to 13 psi by redline.
05-29-2020, 08:34 PM | #271 |
Rep 1,442
Drives: 2011 535i 6MT
05-29-2020, 08:52 PM | #272 |
Rep 104
I don't know. I have not timed the 1/4 mile in awhile. Seems too abusive to the tranny. I will run it again once my tune is done. I'm asking tuner to give me 22-23 psi from 3500-6800 if possible. He likes to see a smooth progressive boost curve. I said damn that - just let me have it! lol
05-29-2020, 09:30 PM | #273 |
Rep 517
With my HOD, AZ inlet leaking, and custom intake making 22 psi all the way up top but 100 wgdc.
Fixed the leak by switching to FTP inlet and put on a semi stock intake now making 20 all the way up top, but still 100 wgdc. No taper in either scenario. Going to readjust the wastegate with the cat off and see if i can fix this 100 wgdc.
05-29-2020, 10:09 PM | #274 | |
Rep 1,299
05-30-2020, 04:05 AM | #275 | |
Rep 104
I think in this case size does matter. The .3" larger AZ inlet compared to the FTP helps make more boost up top. So it seems between each inlet, there is a max of about 3 psi difference. Maybe if Pure bored out the turbo intake a little bigger (1-2mm), we can then make 25 psi. Is the leaking inlet causing drive-ability issues? Maybe your tuner can tune out the mass air flow issue? What about cars that just have a filter directly over the turbo inlet and no intake pipes and maf sensors? |
05-30-2020, 03:03 PM | #276 |
Rep 517
Yeah I've solved my leaks and still have 100 wgdc. Going to try an OTS map and see if the issue still occurs. Changed the solenoid, vacuum hoses, every seal, adjusted WG, pressure and smoke tested it and still have 100 wgdc.
If the OTS gives me a different WG value then yeah, David will have to make adjustments. Here's AZ DShoup tune, stock intake w/open air filter https://datazap.me/u/bmwdoubles/fixe...&data=4-16 Here's FTP DShoup tune, stock intake w/open air filter https://datazap.me/u/bmwdoubles/ftp-...g=0&data=3 I'll post back with a FTP and OTS tune: https://datazap.me/u/bmwdoubles/mhd-...&data=3-14 Damn these OTS tunes are weak. Just spoke with DShoup. Testing the possible fix now.
05-30-2020, 06:10 PM | #277 |
Rep 1,230
N55 GENERAL
05-30-2020, 06:12 PM | #278 |
Rep 1,230
keep in mind im running VP IMPORT which is way different than running e85.
N55 GENERAL
05-30-2020, 07:39 PM | #279 |
Rep 517
This will add 10whp to my reverse
05-30-2020, 07:46 PM | #280 |
Rep 1,230
you dirty dog lol
N55 GENERAL
Bmwdoubles_194.00 |
05-30-2020, 11:11 PM | #282 | |
Rep 517
https://www.ebay.com/itm/181742634599
05-31-2020, 03:47 AM | #284 | |
Rep 104
05-31-2020, 12:46 PM | #285 | |
Rep 1,299
05-31-2020, 01:36 PM | #286 | ||
Rep 517
Turns out that didn't entirely fix the issue and now I max out around 20 psi to redline. So in that, AZ inlet is better inlet. I haven't put my custom intake back on which yielded me 50 more tq. The only thing I haven't refreshed is the wastegate itself. DShoup mentioned the diaphragm in the pneumatic wastegate might be getting weak. Anyone know where to get an OEM wastegate actuator replacement?I looked on FCP but maybe not hard enough. I see Turbo smart has a replacement but I've heard the rod arm is too short. The lag up to 3700 before full boost was due to the unmetered leak and throwing of the MAF reading.
