07-05-2020, 03:50 PM | #397 |
Rep 1,230
yes sir. he put down 521 with leaky diverter valve and i think like 2 boost leaks. Even with that the car feels like an animal!!
N55 GENERAL
David Shoup Tuned Fully Built By Miami Engines/Project Motorworks Precision 6266 On Steroids |
07-09-2020, 05:13 AM | #399 | |
Rep 104
I can only make 21 psi up top with 100% WGDC. Must be our restrictive F10 intake system and small turbo inlet. |
07-09-2020, 09:17 AM | #400 |
Rep 517
That happens to me using the stronger spring on the GFB dv+. It's a shadow code that doesn't affect power and it's normal when tuning on our cars.
BPM Tuned, Advanced Fuel Dynamics, Paddoq Valved Exhaust, Paddoq Magnetic Paddles, EDC dampers, Dinan Springs, H&R Sway. DCT all day long.
https://www.youtube.com/channel/UCFu...fWjCtOz49FDMlg |
PepMo17.50 |
07-09-2020, 08:30 PM | #403 |
Rep 1,299
07-10-2020, 04:50 AM | #404 | |
Rep 104
Have you looked into fitting an S55 block into your car? |
07-10-2020, 09:04 AM | #405 |
Rep 1,230
waaay worth it. The car responds so much better than the GFB!!
N55 GENERAL
07-10-2020, 09:07 AM | #406 |
Rep 1,230
s55 swap would be $$$. I would rather build the motor. S55 you still have to do crank hub fix. DG i steered away from. The manifolds look great but even when your in the case of having the money the guy doesnt get back to you. Have to be on his back night and day and im not with that.
N55 GENERAL
07-10-2020, 10:02 AM | #407 |
Rep 517
Someone would have to be using a 3.5 tmap to get those numbers. 2.5 I'm hitting 21.9. You can check my bmwdoubles datazap and sift through some of the trial runs with D Shoup. My car is almost fixed. When I get it fully operational again I'll post a new log.
07-10-2020, 01:48 PM | #408 | |
Rep 104
07-10-2020, 01:56 PM | #409 |
Rep 104
How do I find your datazap files? I've been trying to get MHD to give us option for a 3.5 tmap on the manifold. I had to remove mine when I made the switch from BM3 because it was giving me error codes.
07-10-2020, 02:32 PM | #410 | |
Rep 517
https://datazap.me/u/bmwdoubles Try this one: https://datazap.me/u/bmwdoubles/run-...15&mark=80 The tmap option should there when you use backend or custom flash settings. It's under one of those.
07-10-2020, 03:35 PM | #411 | |
Rep 104
07-10-2020, 04:38 PM | #412 | ||
Rep 517
According to BMS all we have to do is only replace the the CP tmap and click the MHD option. That wasn't the case for me. So if someone one can figure it out please let me know. D Shoup is looking into it too.
07-10-2020, 05:50 PM | #413 |
Rep 1,442
Drives: 2011 535i 6MT
I'm glad you are back on the horse again!
07-10-2020, 07:28 PM | #414 | |
Rep 1,299
I only did the one on CP as that is the one used for calculation. Last edited by ziekxq; 07-10-2020 at 07:37 PM.. |
07-11-2020, 07:33 AM | #415 | ||
Rep 517
07-11-2020, 12:19 PM | #416 |
Rep 1,299
Yup... The F series they talking about that doesn't require inverting the cable are the ones that come with new design hpfp. I think a lot of people don't know the first gen f series shares 90 percent of everything with e60/90 series.
07-11-2020, 12:36 PM | #417 |
Rep 1,442
100% what I have read.
07-11-2020, 12:44 PM | #418 |
Rep 104
Ahh so you do have the higher flowing HPFP. On my car the 3.5 tmap is plug and play.
