2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Coding: Aftermarket LED headlights
      07-03-2024, 01:15 PM   #1
malakush
Drives: BMW F01 730D
Exclamation Coding: Aftermarket LED headlights
CAR IS F01, BUT LIKELY SIMILAR TO F10/F11
Hello everyone.
I am newbie when it comes to coding, but can follow instructions..
I bought aftermarket headlights from AliExpress for my F01.
They were plug and play, no coding required to work, meaning I haven’t coded anything for them.
I had adaptive bi xenon’s before before.
Main difference is that the new ones are LED and don’t have AFS/cornering lights.
They required to move over the headlight modules from the old lights to the new ones.
I am experiencing the error: side/daytime lights fault.
The angel eyes in the drivers side go out, everything else still works.
As soon as I shut off the car and restart it (even instant restart) they work perfectly again for another 30 min / 1hr.
Which makes me believe it’s a coding issue.
I have scanned it with Bimmerlink and get these two codes in FRM:
800F88: The output daytime running light / left position light has a short circuit
800F8C:
Left cornering light defective
Any ideas?
I have BimmerCode and hoping someone can guide me a little which parameters to change in expert mode.
I think I am looking for a way to code out AFS and cornering lights on my car, but not sure.
Thank you very much in advance!
      07-03-2024, 06:57 PM   #2
B-Buster
Drives: F10 535i, E63 650i
Of course you get errors if you downgrade the headlights without doing the required coding.
The car expects AFS headlights and you installed non-AFS headlights. Need to code out AFS to get rid of those faults.
      07-03-2024, 11:33 PM   #3
malakush
Exactly, which is the reason I am asking for help how to do it via BimmerCode :-)
      07-05-2024, 09:36 AM   #4
Qsilver7
Qsilver7's Avatar
Drives: F06 650ix GC / F15 X5 50i
I just tried a simple google search using BMW code off afs headlights ….and got this result at the very top: https://www.bimmerfest.com/threads/h...ghting.921910/
Since the f10 uses the same control module (FRM) as the f01…perhaps the coding parameters will work for you. There were also other results so try using the same search phrase in a google search to see if the other results have coding parameters that may work for your situation.
Good luck.
Edit: here’s another one using the google phrase above…scroll down to post #10: https://f10.5post.com/forums/showthread.php?t=1932163
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral.
EV8636.50
      07-05-2024, 12:48 PM   #5
malakush
Good luck.
Thank you so much, you're an absolute legend for finding this for me!
For some reason I couldn't find those forums..
I will try the things they described they did. Thanks again!
      07-05-2024, 06:32 PM   #6
Qsilver7
Qsilver7's Avatar
You’re welcome…I hope the coding works for your situation.
Tags
aftermarket, code, coding, f01, headlights, led
