05-22-2022, 07:26 AM | #1 |
Rep 13
520D 11j in the rear
hey guys i am curious... i have been reading alot of different stuff
so atm i drive with JR-28 - front 8.5j 20inch ET18( this is flush... maybe i could go et 17... 16max going lower would poke out) - rear 10J 20inch ET30 (this is also flush... but here i would not go any lower else it would poke) i also am driving on a KW V1 now i have 1rim that is broken and i am looking for new one's i would like to go bigger in rimm size this time my question is now can i run front - 9.5J ET30 or - 9J ET24 Rear - 11J ET43 or 44 or - 10.5J ET36 or 37 how will this go against my suspension ? is this possible for an 520D LCI ? |
05-22-2022, 10:07 AM | #2 |
Rep 29,202
F10 or f11? Different rear suspension on those. I've got f10 with 20x11 et46 and wide 295/30/20 Michelin ps4s tires in the rear.
05-23-2022, 01:57 AM | #3 |
BMW enthusiast since 2004
367
Rep 185
I'm running 10,5" et30 with 275/30r20. No rubbing issues.
https://f10.5post.com/forums/showpos...&postcount=114 I work at tire shop and we've put 11x20 et37 with 275/30 for f10 rear. Last edited by zener; 05-23-2022 at 08:23 AM.. |
05-23-2022, 08:46 PM | #4 |
Rep 262
Not the most aggressive but I'm running 20x9 et32 on Toyo Extensa 245/40R20 in front and 20x10.5 et45 Toyo R888R 285/35ZR20 in rear and car is lowered. No rubbing on suspension, wheel well rub when I go thru a dip at a higher speed. Car is a F10 550i, rear wheel.
2011 550i (N63)
Upgraded 51mm turbos, Heatsync Stage 3 Flash, JB4 stacked, BMS WMI, Arm Charge Pipes, Heatsync Catless DPs, X-Pipe, Res Muffler Delete, xHP Stage 3 Trans Flash, Turbosmart Diverter Valves, 3.5 TMAPs, Oil Cooler, Heatsync Front Mounted Max Cool Intakes, Walbro LPFP and e40 mix rollin on Stance SF07 9x20 w/Toyo Extensa and 10.5x20 w/Toyo R888R. |
