2010 2011 BMW 5 Series Forum F10 Brake upgrades from other BMW models on F10 |
04-17-2023, 11:41 PM | #617 | |
Rep 1,038
I hope I understood your situation correctly. |
04-18-2023, 12:30 PM | #620 | |
Rep 1,356
Here are part numbers to search for: Left Rotor 34116789543 or 34106898731 Right Rotor 34116789544 or 34106894384 |
Blue Angel997.50 |
04-18-2023, 12:40 PM | #621 | |
Rep 251
04-18-2023, 01:05 PM | #622 |
Rep 108
Is there a mistake with part numbers? You suggest iron caliper with carbon carrier
04-18-2023, 04:11 PM | #623 |
Rep 251
04-19-2023, 05:38 AM | #624 |
Rep 1,038
Interesting. So the smaller 348mm version of the G caliper uses a pad that’s compatible with the 374mm version and the 750i rotor. Good to know!
DN, if you go through with the swap please post some close-up pics of the completed setup. It would be good to make 100% sure those pads cover the rotor surface properly. I wonder if the pad selection is better for the 348mm G brakes? There wasn’t much choice when I did my 374/760i setup. |
04-19-2023, 07:37 AM | #625 | |
Rep 251
04-19-2023, 11:12 PM | #627 | |
Rep 1,356
Caliper left 34217848313 or 34217848315 Caliper right 34217848314 or 34217848316 Carrier left 34217848315, 34217845817 or 34217849385 Carrier right 34217848316, 34217845818, or 34217849386 |
04-20-2023, 03:30 AM | #628 |
Rep 34
04-20-2023, 06:08 PM | #630 |
Rep 251
As i taste this Crown🍑 and indulge on my 420 treats im feelin Hopeful🛑 " Choppa" thats my handle
05-12-2023, 07:48 AM | #631 |
Rep 12,565
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.24] |
I spent last hour reading last few pages but was hoping someone could provide definitive parts list for the G series brake upgrade. For the most direct bolt up option…
Front Upgrade to G30 Brakes
Rear Upgrade to F10 M5 Brakes
Install Notes
05-18-2023, 10:44 PM | #633 |
Enthusiast
316
Rep 282
Drives: 2025 M4 Comp xDrive
Thank you Hoa for your amazing service/communication
Got my 374 calipers powdercoated illusion red and installed
2025 M4 Competition xDrive
IG: Automaz_ |
Blue Angel997.50 |
05-18-2023, 10:46 PM | #634 | |
Enthusiast
316
Rep 282
IG: Automaz_ |
Blue Angel997.50 |
05-19-2023, 05:18 AM | #635 | |
Rep 1,038
I do end up with a couple mm more wheel spoke clearance, though, so there’s that. Your calipers look great!!! They really pop behind those black wheels. |
automaz_316.00 |
05-20-2023, 06:02 PM | #636 |
Rep 34
I upgraded my G11 upgrade with an upgrade.
See here. https://f10.5post.com/forums/showpos...&postcount=487 https://f10.5post.com/forums/showpos...&postcount=506 Replaced my upgraded 345x24mm rear brake discs for the F01 370x24mm brake discs. Brackets that are used in the F10 M5 and F06 M6 F01 brake disc Different between 345x24mm and 370x24mm brake disc. Last edited by ptrkp; 05-25-2023 at 05:01 AM.. |
Blue Angel997.50 |
05-23-2023, 10:51 AM | #638 |
Rep 2,591
This thread is single-handedly keeping the used caliper market alive
2015 BMW 535xi
