2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions Retrofit help - 2016 Lci folding mirrors
      08-12-2019, 01:26 PM   #1
harmz
Drives: 430d Gran Coupe & 530D LCI
Hi all
I have got a 2016 F10 which I am trying to install folding mirrors, I have got a set of folding mirrors and drivers door switch. I have seen a guide for pre-lci doing the soldering trick I was wondering if that same method shall work with the lci mirrors and shall the indicators still work ? Thanks for you help
      08-15-2019, 03:22 PM   #2
IINexusII
Drives: F10 520d
Hello,
When i did my 2014 LCI the switch was slightly different and didn't have the same pins where they can be soldered together. Instead i soldered and crimped together the wires going to the same pins.
You need E-Sys to add the correct VO / code the car for the indicators, heated mirrors and auto-dipping to work
harmz5.00
      08-21-2019, 02:24 AM   #3
harmz
Originally Posted by IINexusII View Post
Hello,
Attachment 2121796
That really helps a lot thank you, when you coded the car did you only VO code or did you do any FSL coding aswell? Also did you change of the cables on the passenger side?
I with the mirrors i am installing i am also planning to do the surround view install long side that, which i am assuming has no impact on the install of the folding mirrors apart from running the HSD cables, thanks for your help
      08-21-2019, 04:08 AM   #4
Oreen0
Drives: E90
+1
      08-07-2020, 04:19 PM   #5
IINexusII
Drives: F10 520d
Sorry for the late response!
As far as I remember only VO coding needed, and no changes needed to wiring on the passenger side.
