2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding NBT EVO Retrofit help
      09-02-2019, 01:43 AM   #1
jonobro
Drives: bmw f10 535i
I'm wanting to do a NBT EVO retrofit on my F10 CIC pre-LCI I currently have the HU (with GPS,ID6),G30 screen
CID cable for monitor,Microphone cable,Aux cable,USB cable, BT antenna and Emulator/Adapter that I'm getting real soon I know I need to find someone who can flash and code my unit but is there anything else that I'm missing ? I'm sure I know how to plug everything in I just want to ask someone who has expertise in this retrofit and who has done this before I'm willing to pay just need the help.
      09-02-2019, 02:58 PM   #2
Does this help?
Or this?
      09-13-2019, 03:06 PM   #3
hevykevy420
Drives: '12 328i
I'm curious on this retrofit as well. Keep us informed. The big issue I see is the fact that the F10 screen is inset into the dash, while the G30 sits up outside like my old F30. Is that an issue with fit using the G30 screen?
I have an LCI with USB/aux and also the touch idrive wheel, I'm assuming I'd just need a screen, an EVO head unit, whatever connectors, and coding. But if I have to custom fit the new screen, I'd lean towards just going with bimmertech's carplay/AA upgrade.
2016 528i Msport/Premium/Drivers Assist II/ACC/Cold Weather/Harmon/Pwr trunk
2012 Kawasaki ZX10R ABS
1978 Honda CB750k,
1977 Yamaha XT500
1975 BMW R90/6 & 1969 R69S
      04-24-2020, 08:42 PM   #4
seansimsneill
seansimsneill's Avatar
Drives: 2016 535I 2000 528I
2016 BMW 535I  [0.00]
did anyone do this yet?? I'm looking into it
2016 535i
2001 530i
      04-24-2020, 08:43 PM   #5
seansimsneill
did you try it?? I'm looking into doing the same.. i was thinking of buying G30 head unit and screen
2016 535i
2001 530i
      04-25-2020, 12:27 AM   #6
Nickco43
Nickco43's Avatar
1458
Drives: 08 E92 BMW M3
2008 BMW  [0.00]
I have been looking for a F10 for a while now and will probably pick one up real soon. I have done five NBT Evo retrofits with ATM in E series cars before and I just did one for a F30. You want to make sure you pickup a US spec headunit and a ATM module so you can keep telematics, HD Radio, Sat radio, BMW Assist, etc. On the F30 I even got the remote lock and unlock working with the phone app. I have no idea how it will work on the F10. My car systems dealer put a G30 touch screen in his dash and it looks real cool. I want one in my F10. I put a touch screen with a NBT Evo in a E89 Z4 and it is worth it over a non touch screen. I will do a write up once I find a car.
      05-04-2020, 03:14 PM   #7
seansimsneill
Im going to tackle this this weekend. Just trying to figure out to mount the g30 screen. Any ideas??
      05-25-2020, 04:40 PM   #8
Gangsta
Drives: F10 LCI MY0314
Im planning on this retrofit soon, just need to decide if its worth the extra expense of getting a NBT Evo head unit thats pre-coded to my VIN, since its got afew extras that may need to work. Im being quoted £1090 for the a unit that will also have Carplay screen Mirroring activated and also have the voltage converter wire to conneect to the existing screen (F10 LCI with ID4).
Do you think used NBT Evo head units work with out coding? seen them go for under £400 in UK
Will be great to see some knowledge shared, Im just wondering how much coding there is and if it can all be done using eSYS and ENET cable??
And what is involved when they say coding to VIN, FSC codes??
      05-26-2020, 12:33 PM   #9
seansimsneill
They need coding. Retrofit coding is so different then regular. Go with someone that will help you and does remote coding. You will need more then just the HU to keep Navi as well. Atm and the wiring. I have a guy that helped me. I did G30 screen. Nbt evo HU. G30 controller. And a Atm. I have connected and everything but keep in mind the screen mirroring only works with android
2016 535i
2001 530i
      05-29-2020, 06:03 PM   #10
Gangsta
Thanks for the reply that’s really helpful, I don’t mind paying some one fir the coding, especially to transfer the FSC codes linked to my VIN, also I don’t mind keeping the existing screen using the voltage converter that’s been talked about since I am happy to use the ID4 touch controller for navigation the menus. Most of the NBT Evo headunits I’ve seen are from the F30 will these fit a F10 the look smaller then the NBT unit I have in the car now. Do you know which car your NBT Evo came from? Mind sharing a picture, im seeing some NBT Evo units that have the Blue GPS connector (I’m told these are from Mini)
      05-30-2020, 12:30 AM   #11
dzz
Drives: 2015 BMW 535xi, MHD Stage 2+
2015 BMW  [0.00]
I did G30 screen.
How did you fix G30 screen in place? Is there an adapter for F10?
      07-05-2020, 08:46 PM   #12
tranv117
Drives: BMW 535i F10
Where did you purchase the G30 controller and ATM. I’d appreciate if you can guide me to purchasing these parts?
      11-28-2021, 03:56 PM   #13
ceka
ceka's Avatar
24
Drives: 530d 11'
How did you mount this screen? a specific mount they sell?
      11-28-2021, 04:04 PM   #14
ceka
ceka's Avatar
24
Drives: 530d 11'
This two tabs for the screws.. do they fit without issues in the f10?
