2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications N63 Sport Oil Cooler Valve
      11-27-2020, 06:59 PM   #45
RSf10550beast
Drives: Bmw F10 550
Lol this is funny.. I back Serg 100% he is a stand up guy and always ready to help or answer ??? Even if you don’t buy shit from him.. I’m in SoCal and I wasn’t comfortable buying anything from anyone this far away.. I need to walk into a shop and deal with someone.. I picked up valve, thermostat and stage 2 tune that’s after 2 months of him answering every question I had after 12am est his time.. No One knows these cars better then him and I’m minutes from some of the top BMW tuners.. if that is not customer services I don’t know what is..
550bye1389.50
      11-27-2020, 07:44 PM   #46
AnotherM
Cole
Drives: 2016 m5 CP
Originally Posted by badblack550xi View Post
mind you i have a direct cell phone number you can call instead of emailing me.
this was your 1st email i have ever heard from you
Code:
So I just paid a shop to install this valve and it doesn't fit. I have a 2012 bmw 550i which this is intended for. See attached pictures with factory valve and your valve. Who is going to pay for the lost shop time? Is the part defective?
this was my reply
Code:
That’s how it goes in ! It sits higher !
that makes me a jerk and no one should deal with me ? you gotta be kidding me, do me a favor pack my valve back ill send you return label.
I have to apologize to the seller. At a time of extreme frustration, I misinterpreted your response and was not very understanding. My frustration was aimed at the wrong place and that's not ok.
550bye1389.50
AlexL4.50
      11-29-2020, 12:07 AM   #47
550bye
550bye's Avatar
Drives: 2011 550i
2011 BMW 550i  [5.67]
Code:
this was my reply
Code:
I feel your pain of frustration, your car is essentially broke and I get you being somewhat impatient. It's good to see you apologize and make it right. Good luck with the car, and if you ever think about selling the cooler valve then I am interested.
2011 550i (N63)
Upgraded 51mm turbos, Heatsync Stage 3 Flash, JB4 stacked, BMS WMI, Arm Charge Pipes, Heatsync Catless DPs, X-Pipe, Res Muffler Delete, xHP Stage 3 Trans Flash, Turbosmart Diverter Valves, 3.5 TMAPs, Oil Cooler, Heatsync Front Mounted Max Cool Intakes, Walbro LPFP and e40 mix rollin on Stance SF07 9x20 w/Toyo Extensa and 10.5x20 w/Toyo R888R.
      01-06-2021, 11:31 PM   #48
AnotherM
Cole
Drives: 2016 m5 CP
Car was due for an oil change with all of the miles from the holidays so I put in the valve and it works exactly as advertised.
Again, Sincerely apologize for before to the seller.
550bye1389.50
AlexL4.50
      01-07-2021, 01:02 PM   #49
addy27
Drives: F10 550i
Don't worry, Sergey is an a$$hole..
I kid I kid I kid...no he's an awesome guy!!
Glad it worked out for you!!
550bye1389.50
      10-14-2021, 11:32 AM   #50
TuckerE36
TuckerE36's Avatar
50
Drives: BMW 550i M Sport
OP states will lower engine oil temps to around 200f, my understanding was that engine oil temps needed to be at least 212 to vaporize moisture and burn off deposits in the oil. So lowering below that threshold would negatively impact the engine?
      01-07-2022, 09:21 PM   #51
m5james
m5james's Avatar
Drives: '10 X5M Alpine White on Sakhir
Bump for the above question.
      05-10-2022, 10:25 PM   #52
Joeker
Drives: 2012 550i
2012 BMW 550i  [0.00]
2012 550i  [0.00]
Is the thermostat needed as well to get the temperature below 200°F? If oil cooler valve does a good enough job of cooling the engine, then that is the route I'd rather go.
      09-07-2022, 07:44 AM   #53
badblack550xi
badblack550xi's Avatar
over the the years of having the cooler on my personal cars including my F90 M5 comp, i have not seen any issues. My F10 550i had the cooler installed at 50k miles, it is right now at 150k miles with the new owner.
2011 550i RWD 60-130 7.35
      09-07-2022, 07:45 AM   #54
badblack550xi
Thermostat lowers coolant temps not oil temps, but lower engine temps will slightly make the oil run cooler also.
