2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Considering 535i Larger Turbo
      07-17-2018, 08:44 PM   #1
nels2825
Drives: 2016 Subaru WRX / Audi A6
I am pretty close to pulling the trigger on getting a 2013 535i xdrive. I plan on getting a Pure stage 2 kit right off the bat, although I haven't seen a lot of info on putting them in the 5 series. Is it much different than a 335, procedure wise? I would have thought there would be more working room in a 535 than in a 335 or 135. I know the Xdrive makes it more complicated, but I have seen at least of few 335 xdrives with larger turbos than stock. Anyways, I was hoping to see if someone on here has experience doing the swap
      07-17-2018, 09:00 PM   #2
Stück
Stück's Avatar
Drives: F15 X5, E46 330i, R56 Mini.S
335 is honestly a bit easier, have done and seen both done.
xDrive just makes the job suck bigtime, and take a whole lot longer. on xDrive vehicles the engine gets supported from a cross bridge above and the whole front drive and subframe gets dropped down to make the room.
Get a RWD car if at all possible, they drive a lot nicer and are easier to work on and keep up with less shit to wear out.
      07-18-2018, 05:24 AM   #3
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
+1
      07-18-2018, 03:56 PM   #4
nels2825
Well, the main reason I plan to get it is because of the AWD. I would probably go with something else if RWD was an option. If I had a 2 post lift I would be more confident about dropping the drivetrain by myself, with my scissor lift it is going to be a bit harder. Stuck, I saw you had a kind of write up for this, do you have any pictures of dropping the subframe?
      07-18-2018, 07:08 PM   #5
Stück
Stück's Avatar
Not in the context you're after but these may give you an idea (from when I parted the car out after a kid tboned me)
      07-19-2018, 09:59 AM   #6
nels2825
Wow, that really does look rough. I can see why removing the manifold takes so much longer than switching out the turbo compressor side
      08-12-2018, 08:44 PM   #7
jayster0966
jayster0966's Avatar
Drives: 2011 535i
Following this thread! I have been thinking about doing the same thing with my 11 535.
This turbo setup should work with Bootmod3 tune?
      08-13-2018, 02:04 AM   #8
AZ-MCRacer
AZ-MCRacer's Avatar
306
Drives: 2022 G82 M4, 2013 F10 N55
Yes, I run with Bootmod3.
2022 G82 M4 - Isle of Man Green w/Kyalami Carbon Bucket Seats - MST Intakes, SSR Downpipes, JB4, AWE Exhaust.
2013 F10 N55 (535i), Pure Stage 2, Fuel-It PI Platinum, Fuel-It Stage 2 LPFP, BootMod3, Custom Turbo Inlet, Custom Cary Jordan Tune, More.. SOLD!
1999 e36 M3 - Estoril Blue - Track Car - S54 Swapped
      08-13-2018, 07:41 PM   #9
NinetyEight740
NinetyEight740's Avatar
Drives: 2 - 2013 535i msport
2010 E91  [0.00]
What kind of gains from this turbo upgrade?
      08-20-2018, 11:56 PM   #10
AZ-MCRacer
AZ-MCRacer's Avatar
306
Stock turbo with supporting mods and tune should get you near 350-375 RWHP, with Pure Stage 2, around 450 - 500 RWHP. I will have my car back on the dyno in the fall when ambient temps are lower. I dyno'd last fall at 445HP/498 Ft/Lb but I have a better tune and a proper inlet now.
