2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Bimmer Performance Center N57 Tuning
      10-01-2018, 04:10 PM   #23
Phil@BPC
Phil@BPC's Avatar
465
Drives: E39 M5/ E30 325is
2003 BMW M5  [0.00]
1990 BMW 325is  [0.00]
      10-03-2018, 09:56 AM   #24
Phil@BPC
Phil@BPC's Avatar
465
2003 BMW M5  [0.00]
      10-08-2018, 07:16 AM   #25
W37V
[Oo=||=oO]
Drives: e92n52 & f15n57
Phil@BPC any numbers yet?
      10-22-2018, 09:52 AM   #26
Phil@BPC
Phil@BPC's Avatar
465
2003 BMW M5  [0.00]
I've been out for two weeks for my honeymoon. I'll be working to get information and photos to catch up. Bear with me and Ill post what I can
Here are some photos to update the thread:
      10-26-2018, 09:46 AM   #27
Phil@BPC
Phil@BPC's Avatar
465
2003 BMW M5  [0.00]
VID
VID
Dyno numbers are 450rwhp and 620ft/lbs. It looks like our next hurdle will be fuel.
We found that the stock exhaust, even modded has to much back pressure so we are making fully custom 3.5in back to split 3in to dual mufflers.
      10-30-2018, 09:56 AM   #28
Phil@BPC
Phil@BPC's Avatar
465
2003 BMW M5  [0.00]
Ending up making 30 more ft/lbs at the rear wheels with the new exhaust setup. We still need more fuel to make more power.
      11-05-2018, 08:39 PM   #29
W37V
[Oo=||=oO]
That's a lot of TQ. Do you think transmission can handle it? 50i people are running into issues when they break the 600ft/lbs of tq. You are at 650. Any considerations for upgrading rest of the drive train (shafts etc?).
What limitation with fuel did you run into? Injectors or pumps? If injectors, what injectors are you considering using? Ones from 50d (pt# 13538508153)?
      11-06-2018, 07:21 AM   #30
Phil@BPC
Phil@BPC's Avatar
465
2003 BMW M5  [0.00]
The transmission has been holding up extremely well, even before we pursued this compound setup we had installed an upgraded turbo and tune and then shipped it back to the customer who drove it 30,000+ miles. If we run into a transmission issue we will assess it and come up with a solution for it.
For the fuel system we are keeping that underwraps for now. The customer is eager to get the car back and we have just a few things to finish up.
      12-09-2018, 01:48 PM   #31
auntulna
Drives: 2014 535d, 2005 Passat TDI
"We wouldn't recommend going with a tune and keeping all stock emission components on the vehicle. It can cause issues with the DPF/ SCR system."
Is this still your shop's advice? I had a 335d and fully deleted it with a 2.5 tune. It was a blast, liked it a lot, but now I have a 2014 535d Xdrive, and would be tempted to go Stage 1 and keep the emissions gear in place cuz I'm not as gung-ho as I was before.
Are you finding any problems with Stage 1 tunes? Have there been enough of them to tell?
      12-10-2018, 07:43 AM   #32
Phil@BPC
Phil@BPC's Avatar
465
2003 BMW M5  [0.00]
For both the M57 and N57 we offer stage 1 tunes that are designed for stock emissions still in place. We have sold quite a few stage 1 tunes for both M57 and N57's especially on our black friday sales we had. We have not seen any issues with our stage 1 tunes. We just recently upgraded a customers stage 1 to a stage 2+. They were using our stage 1 tune for over a year with no issues.
Our stage 2 tunes and above are designed as offroad tunes that will only work with the emissions not in place. If you leave the emissions in place with our stage 2 and above tunes it will cause issues with your vehicle and how it operates.
      12-11-2018, 08:28 AM   #33
auntulna
OK, that's good to hear; I have always heard Stage 1 with the rest stock works fine.
Now, to ponder whether to spend money on stereo upgrade versus motor tune. I gotta say, $1000 for computer code is um, um, tough to swallow.
      12-12-2018, 08:47 AM   #34
Phil@BPC
Phil@BPC's Avatar
465
2003 BMW M5  [0.00]
We couldn't leave it alone. On our dyno we noticed that the intercooler was getting pretty hot and with heat a by product of power and heat can kill power we have custom fabricated a larger intercooler for our application. After the fabrication and install we were able to tell a huge difference in the temperature when performing testing on our dyno.
We started off with a core and custom fabricated the end tanks and tubes. I'll let the photos tell the rest.
Custom fabricated mounts and testing fitment of the core in stock location.
Welding up the end tanks
Test fitting front bumper
Tacking the pipes
      12-14-2018, 07:11 PM   #35
W37V
[Oo=||=oO]
Does this mean you have revolved the fuel issue? Also, did you dyno it after the install? If so, where is it now and can we see those graphs?
Thanks
      12-17-2018, 08:47 AM   #36
Phil@BPC
Phil@BPC's Avatar
465
2003 BMW M5  [0.00]
The fuel issue has not been resolved yet. We upgraded the intercooler to bring down the charged air temps. We went ahead with the intercooler knowing we would revisit this once the fuel issue has been resolved and would need a larger intercooler. No changes in dyno numbers. Running cooler temps will help make everything last longer and put less stress on components. The customer will be picking up the vehicle soon and will revisit it later
      12-17-2018, 10:34 AM   #37
W37V
[Oo=||=oO]
Without going all custom, what intercooler would you recommend if one was to perform an upgrade? Is there something that simply bolts on? (this would be for x5 (f15).
      12-17-2018, 11:04 AM   #38
Phil@BPC
Phil@BPC's Avatar
465
2003 BMW M5  [0.00]
The intercooler we were using before we custom fabricated this one was a wagner competition unit. It did bolt in just fine. According to their website this intercooler will not fit the F15.
      01-01-2019, 12:05 PM   #39
WVB
WVB's Avatar
Drives: 535dx M-Sport
Still using one hybrid turbo?
Congrats. Your shop clearly does amazing custom work. I was wondering if a second turbo has been added or are you still running this with a single hybrid turbo. I couldn’t quite tell even with the excellent documentation.
      01-02-2019, 08:06 AM   #40
Phil@BPC
Phil@BPC's Avatar
465
2003 BMW M5  [0.00]
Thank you and the kind words. We added a second turbo to this N57 to make this a compound turbocharger system.
      01-03-2019, 08:45 PM   #41
WVB
WVB's Avatar
Nice! I thought that’s what I was looking at, but being a noob, I really wasn’t sure. Great to see that there is a legit performance upgrade path for the N57. Thanks for the info!
      01-04-2019, 08:38 AM   #42
Phil@BPC
Phil@BPC's Avatar
465
2003 BMW M5  [0.00]
No worries
It is pretty cool to forge a pathway that will open doors for performance on these engines and share what we have found about them.
      01-08-2019, 08:05 PM   #43
jimj911
When the F#$% did we get ice cream?
jimj911's Avatar
Drives: 2008 BMW 335i (E92)
Dyno chart
Would it be possible to see a Stage 2 Dyno chart? You only have the stage 1 on your website and am wanting to see the torque curve for the work you guys did on our car (or similar at least as ours was xdrive and unable to be dyno tuned). Still in love with the way it drives now and no issues !
'08 BMW 335i, Dinan Stage 2
'14 BMW 535d Xdrive Msport, Stage 2
'14 Dodge 3500 Cummins Longhorn dually
'15 BMW X5M
      01-09-2019, 08:57 AM   #44
Phil@BPC
Phil@BPC's Avatar
465
2003 BMW M5  [0.00]
Looks like our photo hosting site is down for a bit but we do have a graph on our website under the tunes. It can be found here: https://bimmerperformancecenter.com/...=6113621540902
The graph is tiny but shows that it produces 308rwhp and 519rwft/lbs.
Once the hosting site is back up I will add the graph to this post.
Edit:
