2010 2011 BMW 5 Series Forum F10 lsturbointeg's "Black Candy" build thread! (with daily/weekly updates!) |
04-22-2020, 02:13 PM | #353 |
Rep 14,521
Lol maybe algebra was just too hard?
04-22-2020, 02:55 PM | #354 |
Rep 14,521
worked on the oil catch can this morning. assembled the bracket to the bracket of the oil catch can
looks pretty good so far wasn't sure if i needed plumbers tape for the threads but found the supplied bag with o-rings so crazy part is when i disconnected the PVC the plastic tubing just cracked and was very brittle! for those wondering here's what it looks like after the oem PVC tubing is removed the 1/2" tubing that came with the kit was not gonna work with the BMW so i went to the Autoparts store and picked up 3/4" tubing. Here's where i left off at. space is super tight where the two tubes come together by. no other way to do this since the OEM tube was probably only 6" long...maybe 5"? the inlet tube is secured but the outlet tube is just mocked up as i'm gonna have to run this across the top where the injectors are and under the intake pipe and around back towards the windshield reservoir. this tubing is not very bendable so i'm having to run the lines out further than back if that makes sense will continue tomorrow morning and i'll take some more snap shots
04-22-2020, 05:31 PM | #356 |
Rep 14,521
yes, the engine cover will fit back on
ey2001310.00 |
04-22-2020, 06:17 PM | #357 |
Rep 717
lsturbointeg9167.50 |
04-22-2020, 06:24 PM | #358 | |
Rep 14,521
04-22-2020, 06:27 PM | #359 | ||
Rep 717
04-22-2020, 06:51 PM | #360 |
Rep 14,521
like i said, bracket can be bought at HD and the 3/4" hose can be bought at Autozone
04-22-2020, 07:09 PM | #361 |
Rep 717
Yes I know but I was hoping the length you needed... all good could just go to autozone and get like 3-4ft hose
04-22-2020, 07:52 PM | #362 | |
Rep 14,521
https://www.homedepot.com/p/Everbilt...-202034301-_-N the hose they have on a reel. $1.99 per foot. i got 6' https://www.autozone.com/heating-and...-hose/4951_0_0
ey2001310.00 |
04-22-2020, 10:13 PM | #363 |
Rep 5,408
OK brother here comes the 1st of what I hope aren't too many questions...
Did you force the hose over the "top" connection (valve cover) or attach the hose to the original connection? |
04-22-2020, 10:43 PM | #364 |
Rep 717
Looks like the top he forced it in and the bottom he used the original connection
04-22-2020, 10:44 PM | #365 |
Rep 5,408
04-23-2020, 08:33 AM | #366 |
Rep 14,521
I first used the connection but because there was no way to get the lower hose on I ended up not using the top connection. Should be fine since it's just a plastic connector with no sensor on it. Tried and tried first but no way can you get both hoses to separate without them kinking. I may try to 90° plastic elbow you mentioned. I'll take a picture of what I mean. Have you done this bro?
04-23-2020, 03:07 PM | #367 | |
Rep 5,408
This sitting around the house has turned me into a professional couch potato!! How did you manage to get that 3/4" hose over the 1" nipple? I've been looking for a 1" to 3/4" hose for that purpose. I found a silicone hose but the manufacturer says it's not for oil use. They said it "could" be used for an oil catch can, but it won't last long. |
04-23-2020, 03:28 PM | #368 | |
Rep 14,521
see how it's right in front of it? you could only bend the tubing so much before you felt like the connector was gonna snap. it's only plastic. here's a close up with the tubes up against each other. probably would be fine? so here's what i ended up doing. took the tubing that came with the kit and it fit right inside the connector. so i did this to both connectors! than used electrical tape to keep them from coming out. here it is back in place and there's no kinking at all which turned out great! here's how i ran the tubing and before anyone ask...yes the engine cover still fits! plenty of room to remove the cup if it needs to be emptied! so there you have it! on to the next project!
ezaircon4jc4554.50 Ickdeep5727.00 |
04-23-2020, 04:04 PM | #369 | |
Rep 5,408
04-23-2020, 04:16 PM | #370 |
Rep 14,521
i just used electrical tape as BMW also used electrical tape for those connections. i suppose if you have the right size heat-shrink you could. i'm guessing it's 1/2" tubing since the one i bought was 3/4"
ezaircon4jc4554.50 |
04-23-2020, 06:08 PM | #371 |
Rep 14,521
Ickdeep5727.00 |
04-24-2020, 11:33 AM | #372 |
Rep 544
interesting!
Project Gamma Intakes / Project Gamma Catless Downpipes / Muffler Delete / DME Stage II Tune / H&R Springs |
04-24-2020, 01:27 PM | #373 |
Rep 14,521
04-24-2020, 01:52 PM | #374 |
Rep 544
