2010 2011 BMW 5 Series Forum F10 Specifications: BMW TwinPower Turbo 4-cylinder engine |
03-23-2011, 11:54 PM | #221 |
Rep 631
I know you're mostly referring to the numbers and not the experience, but a heavily overboosted, relatively small displacement 4 will never feel or perform like a mildly boosted inline 6 across the rev range. It will likely have significantly more lag, be more "peaky" in its power curve, deliver more NVH (of course) and I would be concerned about reliability/longevity if none of the other components are modified to account for the additional power.
No question a chipped 2.0T will be a cheap performance bargain, but a 2.0T +$500 bucks will definitely not equate to a stock 335i. |
03-28-2011, 10:25 AM | #222 | |
Rep 713
Drives: e46 330ci, e92 335i, 2008 128i
04-15-2011, 09:29 AM | #223 | |
Rep 1,347
Drives: 2011 335d
04-29-2011, 04:05 PM | #225 |
Moderator / European Editor
1545
Rep 6,754
There's of course no official word yet, but I would think so. Turbo 4 for the 328 and turbo 6 for the 335 sounds like a reasonable guess.
Best regards, south
11-27-2011, 12:52 AM | #226 |
Rep 319
11-27-2011, 09:21 AM | #227 |
Rep 1,003
It sure did, and it also had at least 100 lb-ft less torque than the N20. And, what little torque it did have, wasn't available until at least 6,800 RPM on the later models and not until 7,500 RPM on the original one with the 2.0l motor. High, low-RPM torque is everyday-usable and enjoyable to drive with. Low, high-RPM torque is only good for the racetrack where sustained high-RPM runs are the norm.
11-28-2011, 12:19 AM | #228 |
Rep 563
My 2007 Pontiac Solstice GXP had 260 hp from a 2.0L turbocharged/twin-scroll 4 with direct injection, and all the power was low in the band with 260 torque and a 0-60 time of 5.5 seconds.
Sadly, since then they've canceled every iteration of the Kappa product, though not because of any fault with the engine. (People stopped buying Suburbans and Silverados for a while. Oh well.) BMW is not really "out in front" of the high-tech 4-cylinder wave, at least not to the extent that they are with dual-clutch transmissions and some other technologies. But I wouldn't say that they're behind either.
2012 135i convertible, DCT, Black/Beige, HK, Prem, M sport, no nav.
12-01-2011, 07:44 PM | #229 |
Rep 563
Here's another significant comparison: The new Z4 SDrive28i (with that 4-cyl, 240hp engine) gets 34 mpg on the highway. The similarly-marketed and popular Mazda Miata is over 800 pounds lighter and has 73 fewer horsepower... yet it gets only 28 mpg on the highway.
Turbo+DI 4-cylers are becoming a tremendous competitive advantage. And their horsepower will only increase. There's really no reason why the TwinPower 4 can't produce *300 hp* with a 3rd-party tune (I had options up to 315hp for my GXP), which means makers have plenty of room to ramp those numbers up over time (while preserving gas mileage). I know nobody's going to agree with me, but I predict the TwinPower 4 series is going to replace the N55 within a few years. Watch. (source for stats above: http://www.foxnews.com/leisure/2011/...-z4-sdrive28i/)
12-02-2011, 07:10 AM | #230 | |
Rep 19,368
Even if this happens, though, the turbo 6 won't go away - it will simply move up a slot and replace the V8. Though the V8 may still remain for higher end vehicles and SAVs. |
