07-12-2023, 07:12 PM | #1 |
Rep 256
Studs or Bolts?
Anybody running studs instead of wheel bolts even if you dont track?
07-13-2023, 09:33 AM | #2 |
Rep 2,637
I personally don't like the look of studs. You can instead get wheel hangers, which thread into the bolt hole and act as studs to help locate and hold the wheel.
https://www.amazon.com/Steel-Wheel-H...w+wheel+hanger Ours are M14x1.25
2015 BMW 535xi
07-13-2023, 10:38 AM | #3 | |
Rep 256
07-13-2023, 12:14 PM | #4 |
Rep 2,637
As long as you're starting the bolts by hand and using a torque wrench, you're fine.
2015 BMW 535xi
Double Nickel174.00 |
07-26-2023, 09:11 AM | #5 |
Rep 116
I went with bolts. Was looking for some titanium studs so I could play around with some spacers I have but ended up just getting these.
09-07-2023, 01:00 AM | #6 |
Rep 184
My wheels are super heavy and it’s very difficult to position the wheels when u do s DIY, also i cross threaded my self with one of the bolt , so i switched myself to stud kits from motor sports recently , and felt better while putting the wheels on.
09-07-2023, 10:23 AM | #7 |
Rep 2,637
Could have easily solved it by just using some wheel hangers.
2015 BMW 535xi
09-07-2023, 11:49 PM | #8 |
Rep 184
thats not the only reason , cross threaded bolts should not be removed frequently so untill i change the hub studs can keep it safe, cause the tyre shop guys dont care abt the cross theraded bolts. impact drivers will make more damages .
