07-02-2020, 03:28 AM | #1 |
Rep 517
Watch out for this one fellows. Recently I've noticed that MHD updates have been sketchy and untested. My monitors weren't working on every update and just prior to that the app was crashing.
Here's what happened. I was having trouble getting the DME to read my 3.5 tmap. The guys from BMS mentioned that sometimes you need to flash to stock and then flash a custom or a OTS map that reads out a 3.5 tmap. I thought easy enough I'll just have MHD flash to stock and then I'll flash a custom map over that. When I flashed to to stock I was getting 160021 crankshaft sensor: can't read position synchronization I found this: https://static.nhtsa.gov/odi/tsbs/20...54820-9999.pdf It seems either the ecu went to sleep or worse. The car almost starts but then dies. Tried ISTA but I don't t have the right ENET cable so it's going to the dealer and I'll have them run it. Also tried to to flash my original stock bin file but same problem. Looks like I have to follow the instructions on that SIB. MHD has been super buggy lately. Be careful with that app.
BPM Tuned, Advanced Fuel Dynamics, Paddoq Valved Exhaust, Paddoq Magnetic Paddles, EDC dampers, Dinan Springs, H&R Sway. DCT all day long.
https://www.youtube.com/channel/UCFu...fWjCtOz49FDMlg |
07-02-2020, 09:33 AM | #2 |
Rep 79
I have to say the new version stalls a lot more in monitoring (Android 10). If Bluetooth is on, it won't even work at all (MHD Wifi). The dials are worse, going into each module is slower. They really need to fix the app
07-02-2020, 10:47 AM | #3 |
Rep 658
I really hope the dealer can get it to come back to life!
11' M-sport- 371WHP - 478WTQ on stock PWG E50 TunedbyShoup // 386WHP - 429WTQ on Shuenk N55+ with ultra-conservative 91 Octane tune // Starting full-range flexfuel tuning in Spring '24 |
07-02-2020, 11:43 AM | #4 |
Rep 517
I'll know soon if the dealer can. I think I could've made it work too had I had the ENET cable and ran the ista tests. I ordered one Incase it happens again.
07-02-2020, 11:55 AM | #6 |
Rep 517
D can and no I've not reached out to MHD yet. I'll let them know. Be careful with flashing back to stock.
ey2001310.00 |
07-02-2020, 02:03 PM | #7 |
Rep 418
Bmwdoubles_194.00 |
07-02-2020, 09:39 PM | #9 |
Rep 14,522
Ugh...reasons why I haven't flashed yet
07-02-2020, 09:47 PM | #10 |
Rep 716
Are you near la? If you want to try I have the black WiFi adapter... I have the kdan cable too but I stopped using it after the iOS update
Bmwdoubles_194.00 |
07-02-2020, 11:49 PM | #11 | |
Rep 418
There are some prerequisites for flashing a tune with MHD, few important things are to fasten driver's seatbelt so that the car doesn't turn off, to put Android or IOS device in the airplane mode and don't open/close doors or do anything with the car while the flashing is happening. Like I've said, I never has any issues with MHD or XHP running on Android or IOS. |
Bmwdoubles_194.00 |
07-02-2020, 11:53 PM | #12 | ||
Rep 716
07-03-2020, 10:20 AM | #14 | |
Rep 517
I have an ENET cable inbound for ISTA, but in any case I sent it to the dealer. My TO bearing went out so I'm going have look at that too while I'm out of town. When I return and it's not fixed and ISTA can't fix it then I'll hit you up. Appreciate the offer.
ey2001310.00 |
07-03-2020, 10:21 AM | #15 |
Rep 517
I was thinking about this Seeing how buggy MHD has been lately.
07-03-2020, 12:05 PM | #16 |
Rep 658
As a general note (and this was determined to have been the root of the issue with that other thread a couple months ago with a similar issue). Any time you do a flash, make certain that you have the latest version of the app, and that your device (phone/ tablet, etc...) is also running the most current version.
Not saying that this was the issue in this case, but just putting it out there for all to note.
07-03-2020, 12:31 PM | #17 | |
Rep 716
07-03-2020, 01:28 PM | #18 |
Rep 1,442
Drives: 2011 535i 6MT
I have messaged MHD directly from facebook and they responded during their normal business hours and provided good customer service to help me trouble shoot my issue.
And reading posts on facebook is like looking at reviews on google... most the time the people who bother to complain are the ones who have issues, so it's not representative of the product all the time. Unless we are all fake. |
07-03-2020, 01:48 PM | #19 | |
Rep 658
Mind if I ask what they determined was the issue here? (for others to be on the lookout if they have a similar situation)
07-03-2020, 02:50 PM | #21 |
Rep 1,873
I know that getting it to start again is of utmost importance, but be careful what you wish for from the dealer. I'm not sure if it applies to all HARDWARE revisions of the ECUs, but BMW has changed their code and cryptography and after a certain revision you can no longer crack ECUs with flash tunes.
The TL;DR is that you might get it back from the dealer running, and now be unable to install MHD, BM3, xHP or any flash-based tunes of any kind without doing a bench flash (remove the ECU and send it to be cracked). |
07-03-2020, 02:59 PM | #22 | |
Rep 1,442
