12-19-2021, 08:38 AM | #1 |
Rep 16
Bmw f10 battery drain?
Hello there.
I got a strange problem with my 2010 bmw f10 535i.. It occasionly wont start when pushing the start buttom, but the lights turn on and wipers go off automaticly.. there is no light in the dash and it the car wont even crank. Ive tried reading the fault code and cant connect becouse there is no connection, but if i take the negative cable of the battery and put it on again, everything is fine? Thr battery is new, so thats not the problem. Anybody tried anything similar? |
12-20-2021, 07:24 AM | #2 |
Rep 658
too many variables. If removing and reinstalling the negative terminal "fixes" the issue and allows you to start... it tells us the battery isn't the culprit.
You need to take the car to someone who can do a drain test and go from there. Any module, the distribution box, a random accessory could be on and cause this
11' M-sport- 371WHP - 478WTQ on stock PWG E50 TunedbyShoup // 386WHP - 429WTQ on Shuenk N55+ with ultra-conservative 91 Octane tune // Starting full-range flexfuel tuning in Spring '24 |
03-06-2022, 01:34 PM | #4 |
Rep 16
Never found out what the problem is and still happens sometime.
I did a parasitic drain test and there was non. I got ista and everything seems to respond as it should.. |
01-16-2024, 09:26 PM | #6 |
Rep 55
I have a 2013 550i I had the issue where it not crank or start I think it’s battery cause I have a battery discharge message I think it can be a fuse in in the engine? Tell me what to do how to fix it?
01-17-2024, 12:44 AM | #7 |
Rep 233
Drives: 2015 BMW 535i M Sport
razfrankel
You're probably going to have much better success if you create a new thread specific to your problem instead of posting the same or similar questions on 3 older threads. That way all of the troubleshooting information and all of the actions that you've done in regard to your issue is in one place. That will help others to help you. Sounds like you most likely have a parasitic drain somewhere (as a member in another one of the threads you posted in pointed out as something to diagnose prior to replacing your battery). |
01-18-2024, 01:31 PM | #8 |
DIY Mechanic
77
Rep 127
Drives: 2012 BMW 535i xDrive
You state the battery is new but is the battery coded to the vehicle?
You can live in a car but you can’t race a house.
01-26-2024, 07:30 PM | #9 |
Rep 435
Drives: 2016 F10 BMW 535i M Sport
As mentioned above, was the new Battery Programmed to the car? sadly it isn't simply plug and play.
